Need a little bit more help getting my station set up.
Rooster
Post by Rooster »
Hey everyone
I need a little more help getting my station reporting to WU. I have a dir 505 flashed with meteobridge, a Davis vantage vue, and a belfryboy logger. I have the dir 505 flashed correctly and it's working fine over Wi-Fi. Now k can not get my station to report to WU. It says my station name and password are correct. So under the stations tab in MB, I choose my station, then I have options for USB or IP. Which one do I use? I have tried both and neither are working for me. If I choose IP, what IP do I use? I looked as much as I could and couldn't find anything. Do I need a usb 2.0 hub Maybe? My time is set correct in MB. Something, somewhere is not communicating directly.
Thanks for all of your help.
Re: Need a little bit more help getting my station set up.
Have never seen a Belfryboy logger so running a little blind here. How does this logger connect to the MB/DIR 505?
Rooster
Post by Rooster »
It connects to the logger via usb. The guy who sells them basically copied what Davis makes. But I was unsure to label it as usb or IP, since it connects via usb, but the 505 is WLAN, you know?
The MB Station Tab would then be set to USB, the LAN (or WLAN) connects the MB to the outside world for upload etc
And yes you may need a USB hub? I have seen reference to this being a requirement for different USB versions.
Rooster
Post by Rooster »
Hmmmm, that's exactly how I have it set up now, and it's not reporting. I'll post a screenshot when I get home.
Also, when I go to the system tab, I have the check box marked where it says "Allow login from the Internet via this URL". However, when I use that URL, I get this error "Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later."
I'm wondering if they're related, maybe I have something messed up somewhere.
Rooster
Post by Rooster »
I got it :) a simple reboot, unplug and re plug and reboot fixed everything :) thanks again for your help!
