Totally Confused
Totally Confused
Hello I finally got around to installing some new hardware and installing the meteobridge Boris sent me some months ago.
But I am totally confused on the wind values I cant determine what is the wind gust what is the max wind gust value ..
im using the weather34 homeweatherstation option hopefully some of you experienced guys will have some knowledge on what is the value for wind gust...brian
Re: Totally Confused
weatherist34 wrote: Tue Oct 03, 2017 3:31 pm Hello I finally got around to installing some new hardware and installing the meteobridge Boris sent me some months ago.
wind is the name of the sensor used for all speeds of the wind.
gust-speed is the highest value in any period of the sensor wind
wind-speed is defines as the average for a defined period of (I think) 10 seconds but depends on the weather-station.
gust: [wind0wind-act.1:0]
wind: [wind0avgwind-act.1:0]
With Meteobridge (and Meteohub) the sensors are the first part, explained at http://meteobridge.com/wiki/index.php/Templates
Examples at the bottom of that page use gust: Max gust in last 10 minutes was: [wind0wind-max10.1:0]
wvdkuil wrote: Tue Oct 03, 2017 7:47 pm
good morning Wim
thank you now I get it ...so for homeweatherstation api use
it is note Im using the multiplier from ms to kmh ...livedata.php
$weather["wind_direction"] = number_format($meteobridgeapi[7],0);
$weather["wind_direction_avg"] = number_format($meteobridgeapi[46],0);
$weather["wind_speed"] = $meteobridgeapi[5]*3.6;
$weather["wind_speed_avg"] = $meteobridgeapi[12]*3.6;
$weather["wind_gust_speed"] = $meteobridgeapi[6]*3.6;
$weather["wind_speed_max"] = $meteobridgeapi[30]*3.6;
$weather["wind_gust_speed_max"]= $meteobridgeapi[32]*3.6;
if its wrong can you help im somewhat new to it but have only just installed some new hardware and now im going to utilize the mysql from the meteobridge into the template release sometime soon.also really improve the template for meteobridge use currently using the mysql at https://weather34.com
brian
weatherist34 wrote: Wed Oct 04, 2017 9:12 am good morning Wim
. . . shortened . . .
brian
I am not familiar with the $meteobridgeapi array you are using.
And therefor I can not see / study the [Meteobridge tags] which are used to fill that array.
Succes, Wim
wvdkuil wrote: Wed Oct 04, 2017 12:14 pm
brian
Succes, Wim
i had this from some months ago to work with
line 1 time/date finishes at line 66
for example(s)
$weather["temp"] = $meteobridgeapi[2];
$weather["barometer"] = $meteobridgeapi[10];
line 1 [DD]/[MM]/[YYYY] [hh]:[mm]:[ss]
[th0temp-act:--]
[th0hum-act:--]
[th0dew-act:--]
[wind0avgwind-act:--]
[wind0wind-act:--]
[wind0dir-act:--]
[rain0rate-act:--]
[rain0total-daysum:--]
[thb0seapress-act:--]
[wind0dir-act:--]
[wind0wind-act=bft.0:--]
m/s
C
hPa
mm
[thb0seapress-val60:--]
[rain0total-monthsum:--]
[rain0total-yearsum:--]
[rain0total-ydaysum:--]
[thb0temp-act:--]
[thb0hum-act:--]
[wind0chill-act:--]
[th0temp-val60:--]
[th0temp-dmax:--]
[th0temp-dmaxtime:--]
[th0temp-dmin:--]
[th0temp-dmintime:--]
[wind0avgwind-dmax:--]
[wind0avgwind-dmaxtime:--]
[wind0wind-dmax:--]
[wind0wind-dmaxtime:--]
[thb0seapress-dmax:--]
[thb0seapress-dmaxtime:--]
[thb0seapress-dmin:--]
[thb0seapress-dmintime:--]
[mbsystem-swversion:--]
[mbsystem-buildnum:--]
[wind0wind-max10:--]
[uv0index-act:--]
[sol0rad-act:--]
[wind0dir-avg10:--]
[rain0total-sum60:--]
[mbsystem-daynightflag:--]
[wind0dir-avg10:--]
m
[mbsystem-daylength:--]
[uv0index-dmax:--]
[th0hum-dmax:--]
[th0hum-dmaxtime:--]
[th0hum-dmin:--]
[th0hum-dmintime:--]
[th0dew-dmax:--]
[th0dew-dmaxtime:--]
[th0dew-dmin:--]
line 66 [th0dew-dmintime:--]
brian
@Brian: Meteobridge provides direct support for "Home Weather Station" template. You can select sending data in that format on "Weather Network" tab. But may be you are going to add things not implemented in the standard upload defined there?
