No longer connecting **solved**
asherah
Post by asherah »
Hey guys, I'm a new Meteobridge user, just flashed my MR3020 today. After a shaky set-up, I finally got my MR3020 to send data. It was working well with rapid fire updates to WU for almost an hour when it unexpectedly stopped. I got an error message, (error connect socket 192.168.0.13: port 22222: No route to host). I'm not sure where I went wrong in setting up my devices. I have a Davis Vantage Vue with the IP data logger. These are the messages I'm receiving. Thanks in advance for the help!
logger (19.12.2017 18:15:05): historical data loaded (19 records).
logger (19.12.2017 18:15:05): data logger (version 5.0w, build 11742) started.
logger (19.12.2017 18:15:08): error connect socket 192.168.0.13: port 22222: No route to host
logger (19.12.2017 18:15:12): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (19.12.2017 18:15:12): services paused.
logger (19.12.2017 18:15:38): error connect socket 192.168.0.13: port 22222: No route to host
logger (19.12.2017 18:16:38): message above repeats 2 times.
logger (19.12.2017 18:17:05): give up waiting for sensors after 120 secs.
logger (19.12.2017 18:17:05): services activated.
logger (19.12.2017 18:17:08): error connect socket 192.168.0.13: port 22222: No route to host
logger (19.12.2017 18:19:38): message above repeats 5 times.
asherah
Re: No longer connecting
Post by asherah »
To add to this issue. I disconnected the Ethernet Cable from the meteobridge MR3020 and connected it directly to my modem and my data logger is uploading data to WU and also the Meteobridge software.
Re: No longer connecting **solved**
looks like you have not given your Davis WLIP logger a fixed IP address and therefore it has turned out being no longer reachable at the IP entered on the Meteobridge "station" tab.
