Bad sensor data
patreeot
Bad sensor data
Post by patreeot »
Here's the issue I've been having. I recently updated the license. When setting up the Meteobridge, I can setup the network and attach the weather station, however I can't upload to Wunderground or Ambient. Under Live Data they are listed as "No weather network traffic". Here's the messages under System:
wnetd (02.01.2018 20:37:07): process started.
system (02.01.2018 20:37:07): start of logging process initiated.
logger (02.01.2018 20:37:08): historical data loaded (19 records).
logger (02.01.2018 20:37:08): data logger (version 5.0w, build 11747) started.
logger (02.01.2018 20:37:08): connect station 0 (WH-1080/3080 via USB HID).
logger (02.01.2018 20:37:09): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (02.01.2018 20:37:09): services paused.
logger (02.01.2018 20:37:23): Bad thb0(0) sensor data, "pressure x10" (0) out of range [4000:13000]
logger (02.01.2018 20:39:01): message above repeats 7 times.
logger (02.01.2018 20:39:09): give up waiting for sensors after 120 secs.
logger (02.01.2018 20:39:09): services activated.
logger (02.01.2018 20:39:16): Bad thb0(0) sensor data, "pressure x10" (0) out of range [4000:13000]
logger (02.01.2018 21:10:17): message above repeats 132 times.
If I'm reading it right, I have a bad barometer (shows up as 00.00 on the station console), and that is preventing the Meteobridge from submitting data. Is this correct?
Chris
Re: Bad sensor data
yes.
