Stopped reporting data to some services **solved**
tloomos
Post by tloomos »
I have Meteobridge v3.5 build 11751 running on a DIR-505 and it seems to have stopped reporting data to Weather Underground.
It appears to still be reporting ok to WeatherCloud, WeatherBug Backyard, Weather For You and CWOP, and it's posting my webcam pictures to Weather Underground, but it's not sending data updates to Wunderground.
It was working fine until earlier today. I tried rebooting, but the problem remains.
In the log, I see entries like this:
2018-01-07 23:36:20 Error: No data received. (19 more tries)
2018-01-07 23:36:14 Error: Read error (Connection timed out) in headers. (20 more tries)
Any suggestions what I could try to fix this?
Re: Stopped reporting data to some services
tloomos wrote: Mon Jan 08, 2018 7:53 am I have Meteobridge v3.5 build 11751 running on a DIR-505 and it seems to have stopped reporting data to Weather Underground.
Everything with Wunderground is broken it is not unique to meteobridge. For instance there are over 100 stations here in Istanbul but only 4 are showing up on Wunderground..
I’m on 3.3 exactly same problem my guess is the Wunderground servers is not reachable at times regardless of wether your using meteobridge or any other method to send PWS data. Guessing it is Probably related to there rapid fire service . But who knows but rest assured it’s not a meteobridge problem.
Brian
WU has currently lots of problems. You can read here: http://www.wxforum.net/index.php?board=90.0
