Weather Underground Rapid Fire ** solved **
pirelli
Post by pirelli »
I have used it with success until version 2.4b.
Now it says: Weather Underground "Rapid Fire": stopped when rapid fire is checked under Weather Networks.
If I uncheck it, the message disappears.
But Rapid Fire doesn't work in either way.
Re:Weather Underground Rapid Fire
Display of rapid fire status is buggy in version 2.4b. Will be fixed in 2.4c.
Apart from that, I don't have an idea why rapid fire is not working with your system. Does it never work? Or does it stop going after a while?
pirelli
Re:Weather Underground Rapid Fire ** solved **
Post by pirelli »
It seems to stop working after the initial display of the current wind speed.
Even if the meteohub has been set to update every 30 seconds it doesn't.
That has been working before.
And it works now again when I installed 2.4e. :woohoo: :woohoo: :woohoo:
