I am now to meteobridge, so this is my first post. I have been a weather display user for about 14 years, just moved over to meteobridge so that I can continue to use the excellent weather34 template.
I apologise if this is a silly question, but is there any way to get meteobridge to upload the monthly and annual records. I know it stores them, but not sure if it is possible to upload them somehow? I can’t use Mysql as my host (one.com) won’t allow remote connections.
I am using a Davis vp2 with a tplink mr3020 router running meteobridge software.
Paul
Monthly and annual records **solved**
Re: Monthly and annual records
You need to enter it manually on the live data page. Once done the system writes these on.
Thanks for replying so quick. Does it write them to the MBrealtimeupload.txt? Does it upload all monthly and annual records? I assume they are uploaded in the order they appear in the live data page?
Paul
Paul
Is there a list of what the values all are in MBrealtimeupload.txt? I updated the all time solar energy today in live data screen but it doesn’t appear in my real-time file? Http://www.paulwilman.com/pw1/mbridge/M ... upload.txt
I am part way through setting up a dead simple template that will upload monthly, annual and all time records (http://www.paulwilman.com/weather_records1.php) shows the work just started. I am struggling to format the date of the record. At the moment it is being returned as a string (see first monthly record). I would love to format it as dd/mm/yy. Is this possible, and if so could someone help with the syntax I need to use.
I have tried using the suggestions in the template wiki, but doesn't seem to work.
Paul
Paul
Would you like to share your self-defined template? Without knowing it one can hardly help you.
Manage to sort it out, and work out the correct syntax for date outputting. Here is the link to my template incase anyone else wants to use it...
http://www.paulwilman.com/weather_records.php
Can share actual template if people want it.
I am very new to meteobridge, but great that it is able to produce templates
Paul
Paul
