Can’t login to meteobridge **solved**
pwilman
Post by pwilman »
I can’t seem to be able to login to meteobridge at the moment. I go to the IP address and the meteobridge login comes up. I put the correct login details in and meteobridge just returns to the login page. I am running the tp link mr3020. It is still sending data to my website, just can’t login.
Meteobridge is also sending data to weather display via port 22222. This is also seems to have stopped and weather display is just getting the same data I.e if has flatlined for about 2 hours now.
I have rebooted the router but still get the same issue.
I hope someone can help.
Paul
Re: Can’t login to meteobridge
Did you try to reset password? Did you try to check the IP?
Wiki contains a lot of information about that in the "getting started" section.
pwilman
Can’t login to meteobridge (SOLVED)
Post by pwilman »
Ip address was fine. It was the password. Did a reset via the router and all started working. Thanks so much for helping
Paul
