Data stopped flowing
tloomos
Post by tloomos »
I'm at a loss here and hoping someone can point me in the right direction. Around the beginning of January, Meteobridge looks like it stopped pushing data up to the weather networks. Wunderground is the main service I look at, so I thought this was related to some of the issues they had recently, but I see other stations appear to be back online and functioning normally, but not mine.
I did a deeper dive today and tried to completely reset things. I deleted all of my historical data, completely removed and re-added my weather station and did a few reboots of Meteobridge along the way. I'm running v3.5 build11925, FW 1.3 on a DIR-505. I'm using an Acurite 5-in-1 weather station with the network bridge to connect to Meteobridge. I have 4 weather networks configured (Wunderground, WeatherBug, Weather For You and CWOP).
Here's the thing that has me baffled: On the Live Data tab, I see accurate weather info being reported to MeteoBridge, and I see successful pushes to the weather networks. When I click on the green checkmarks to see update history, I see all Success messages, no failures.
However, when I login to the weather networks, I see:
Wunderground: No updates recorded except it seems to be getting pressure?
WeatherBug: Looks like data is coming in, but showing temp of 140! (temp I see in Meteobridge live data is 55)
Weather For You: Similar to Wunderground, only pressure is showing
CWOP: Similar to Wunderground, only pressure is showing
Also, WeatherBug, W4U and CWOP all show last updated times within a couple of minutes and it refreshes, so it seems like they are getting connections from Meteobridge, but no data?
I'm really not sure what else to dig into, look at or replace in order to get things back online.
Any ideas or suggestions would be greatly appreciated!!
Thanks!!
tloomos
Re: Data stopped flowing
Post by tloomos »
I cant figure out why I would see good data in the Live Data tab, and see success messages in the logs for the weather networks, but the weather networks wouldn't show updated data.
Is there a way on any of the weather networks to see a more raw data view of what is being received?
