Log message
SPW55
Log message
Post by SPW55 »
I'm having trouble with my Meteobridge Pro after a adjusting the Pressure setting correction and having done a reboot I'm now getting a log with the below details and the Meteobridge going in to the standby with the two vertical lines details read
log message pipe "/dev/meteobridge" failed: Too many open files
logger (05.02.2018 11:45:07): message above repeats 587 times.
SW Version :Meteobridge 3.5 (Feb 5 2018, build 11934), FW 1.4
any suggestions please
Re: Log message
reboot
SPW55
Re: Log message
Post by SPW55 »
I rebooted a couple of times and the unit ran ok for a while then stopped with the black screen I checked and rebuilt the files then rebooted but I still had the same problem, so have reverted back to an earlier version and now it has settled again, I was trying to reset the pressure settings to bring it up to date but was having trouble adjusting as nothing was changing so at the moment it is running just on Version 3.0
Re: Log message
Can you please give me remote access? I would like to rule out a HW problem.
Please send credentials to "info(at)meteobridge.com".
