Raspberry Pi Zero W
Volker S
Raspberry Pi Zero W
Post by Volker S »
Is the Raspberry Pi Zero W compatible with meteohub? Because it has the same CPU as Raspberry Pi B/B+ (Link) I think I could use it.
-volker-
Re: Raspberry Pi Zero W
We don't have a port for it.
Volker S
Post by Volker S »
What port do you mean?
The Pi Zero W has WLAN and USB. What is missing?
-volker-
I think that refers to software/firmware porting?
Volker S
Post by Volker S »
admin wrote: Fri Feb 09, 2018 4:25 pm We don't have a port for it.
Can you explain it in a short way? Has that been tried?
-volker-
As Meteohub is designed as a headless unit, a device without LAN is not fitting. How should one insert the credentials for WiFi?
Would need complicated Access Point operation in the beginning and then switching over to a WiFi client... much hassle... for what? Just for saying it also supports this device type? I don't really see the benefit.
When you want it really small and less power hungry, you can go with Meteobridge.
An$ar!01
Post by An$ar!01 »
What I did was connect my Meteohub in another Davis 6152, configure all things and then connect again on the other Davis with Belfryboy Clone USB logger. Now it's working fine.???
