Meteobridge lost connection **solved**
Robbie936
Post by Robbie936 »
I had a power outage of 1 hour. After the outage the meteobridge has a continuous fast blink red light. I have rebooted and re powered with no luck. The router can see the meteobridge connected. I tried the cloud simulator but it does not seem to work - may not have all the right info. I have IP netmask and gateway but not sure what to put in the DNS box.
Currently the meteobridge is sitting with fast flashing red LED and the word REBOOT.... on the screen
Thank you
Det
Re: Meteobridge lost connection
Post by Det »
I have the same problem after a router reboot. Even a reboot of Meteobridge does not work. At the moment the Meteobridge is sitting on the screen with a fast flashing red LED and the word REBOOT ....
Thanks for any help
screamingdead
Post by screamingdead »
Same problem with my Meteobridge Pro after a restart last night.
"Meteobridge application stack you wanted to access could not be loaded from the Internet"
screamingdead
All working again now.
Det
Post by Det »
Now it works again. Which spirit was that?
Robbie936
Post by Robbie936 »
Mine is up and running again, must have been a problem at Meteo HQ downloading the stack (whatever that is).
It would be nice if the bridge was clever enough to say it had a problem rather than leaving it a bit ambiguous with REBOOT....
Live and learn I suppose.
vintner
Re: Meteobridge lost connection **solved**
Post by vintner »
I have this exact problem just now, my pro can connect to the internet but is unable to download the stack.
Did you do anything to fix it? or did it just fix spontaneously?.
thanks
Do you still have the problem?
jpouyaud
Post by jpouyaud »
Would be great to have a response to the question asked by the users
jpouyaud wrote: Wed Nov 10, 2021 6:00 pm Would be great to have a response to the question asked by the users
Would be great if you don't hijack threads for just complaining.
jpouyaud
Post by jpouyaud »
well, it's not an hijack, I'm suffering something very similar
My RPI is able to boot only 1 time over 10 with meteobridge
When I look on the RPI screen, I see a normal boot process with openwrt
when I look the webpage, I see the RPI to download the binary on the cloud.
then we have a reboot, and the RPI is "dead", no ping anymore
Asking a support here to find what's wrong
I can't say what is wrong with your network setup that blocks the Meteobridge to connect to the Meteobridge server and to load the application stack from there. Other Meteobridges around the world work fine.
If you have a RPI 4 those are sometimes a bit picky with some 100MB switches. (so try connecting to another switch) Are you operating LAN or WLAN?
ruzzi.f@gmail.com
Post by ruzzi.f@gmail.com »
this is exactly what is happening since few weeks to my meteobridge pro. I have 3 meteobridge pro, in different location and connected via lan to their router. I can access to them during the boot fase, but after that they die and csnnot ping them anymore.
2 MB pro with same issue. Also the third had the issue for 1 week but after a reboot it was able to complete the boot fase.
