MB says its sending data, Weather Networks say it is not
tloomos
Post by tloomos »
I've been having an issue with my MB that I can't figure out. I've rebooted, made sure I'm on the latest version, etc. No settings have changed since the last time it worked (which has been a couple months ago now).
The Live Data tab shows accurate data and that data is being sent successfully. If I click the green checkmark to see the logs, I see all Success! messages, no failures at all. But if I go to any of the weather networks I have setup they show no data.
Wundergrond for example shows "Station last reported 14 seconds ago" type messages, but no data.
Any suggestions what I could try to sort this out?
Re: MB says its sending data, Weather Networks say it is not
WU is probably explainable, how many other networks are you sending to and which ones?
tloomos
Post by tloomos »
I'm also sending to:
  • WeatherBug
    Weather For You
    CWOP
    AWEKAS
These all "used to" work, but it's been close to a couple months now since I've seen any data going through. The logs in MB show "Success!" and the live data looks right, so I don't know where eles to look. The fact that multiple networks are involved makes me suspect something on the MB/My end as opposed to the weather networks.
I've tried clearing all my data, removing/re-adding my weather networks, changing the weather station and then changing it back. I just don't know where else to look. I'm fine with doing a full reset if I can figure out how - if that's the next step to try?
If your live data is good and nothing getting sent to weather nets then what is your internet like?
When you give me remote login I can check, why uploads fail. Please send credentials to "info(at)meteobridge.com".
