WeatherFlow Stations AIR and SKY supported
We just released a Meteobridge version that supports the brand new WeatherFlow stations AIR and SKY. Please find details here: http://meteobridge.com/wiki/index.php/Forum#Version_3.6
Station AIR provides pressure, temperature and humidity, SKY provides wind, rain, uv and solar radiation. Both connect to a wireless HUB which makes them available in your LAN/WLAN and to the Internet. Stuff is expected to be public available next month.
Re: WeatherFlow Stations AIR and SKY supported
good morning boris
just to confirm template works fine i will email you later this week ..
lightning detection of AIR station has been added with latest update. Data can be used by template variables "lgt0dist" to have distance reported (in kilometers) and "lgt0total" to get number of lightning strokes in a certain period of time.
...plus "lgt0energy" to see the intensity of the lightning stroke. This value does not have a physical unit, it just gives some magnitude comparison information.
thanks for you patience this weekend Boris everything is now perfect :-). awesome support again...thank you brian
doubleohwhatever
Post by doubleohwhatever »
Is the WeatherFlow station now an option on the "Station" tab (in Meteobridge)?
doubleohwhatever wrote: Thu Apr 12, 2018 8:42 am Is the WeatherFlow station now an option on the "Station" tab (in Meteobridge)?
Yes, Weatherflow: AIR and SKY
Boris,
I am using a DIR-505 with Meteostick and a Davis Vantage Pro 2 Plus station. I am planning on testing the new Weather Flow station. I also use Brian's Home Weather Station Template. I know Brian plugs the Weather Flow hub into the Meteobridge via USB to grab the data. Would it be possible to use a USB hub and attach the Meteostick and Weather Flow hub, keeping the Davis as the main station?
Currently Meteobridge does just support one station at a time.
Andyk1
Post by Andyk1 »
I hope this is not off topic but I am very interested in the WF array. Have been reading as much as I could and regret I did not get one during the Kickstarter campaign. The main thing I am looking for since this is not a cheap after you get all 3 or 4 if you include the hub add on devises is, has anyone lost one due to lightening. I don't mean a direct lightening strike but close by and the static a near by strike causes. Over the years I have lost so many devices including SDR radio's I pretty much gave up on expensive. I have been using an Ambient WS-2902 (Cost $120.00 US dollars) the past 6-7 months but we are just getting into our thunderstorm/Tornado (Oklahoma USA) season but not really near by or close storms to tell how well this will keep up.
The reason I ask is because I have been on WF's site and see there are allot of dead stations (Some off line over 3 months) and curious why that would be if anyone could answer that.
Andy
Andyk1 wrote: Mon Apr 30, 2018 9:29 am I hope this is not off topic but I am very interested in the WF array. Have been reading as much as I could and regret I did not get one during the Kickstarter campaign. The main thing I am looking for since this is not a cheap after you get all 3 or 4 if you include the hub add on devises is, has anyone lost one due to lightening. I don't mean a direct lightening strike but close by and the static a near by strike causes. Over the years I have lost so many devices including SDR radio's I pretty much gave up on expensive. I have been using an Ambient WS-2902 (Cost $120.00 US dollars) the past 6-7 months but we are just getting into our thunderstorm/Tornado (Oklahoma USA) season but not really near by or close storms to tell how well this will keep up.
Andy
offline/dead stations are field test units not permanent ,probably the phrase dead is a bit misleading ,it would be upto the maintainer gary to eliminate dead stations its not automatic and gary has no association with weatherflow apart from field testing hardware.soemthing he developed..
as for nearby lightning you i get it ,last july was as worse as it could be the air model recorded some 3000 or more strikes in one day it survived but one of our upstairs tvs and dvd players did not ... https://weather34.com/lightning/lightning2017.html
like anything electrical when storms nearby you got to take some precautions ahead ..
GaryFunk
Post by GaryFunk »
Did someone mention my name?
GaryFunk
Post by GaryFunk »
Andyk1 wrote: Mon Apr 30, 2018 9:29 am The reason I ask is because I have been on WF's site and see there are allot of dead stations (Some off line over 3 months) and curious why that would be if anyone could answer that.
Andy
Andy,
The Map you refer to is a personal project of mine. When a station has stopped reporting data for more than 30 days, I mark it dead. I have no idea why it stopped, it could have simply been taken offline.
