Template errors/advice
garyb
Post by garyb »
I'm trying to create a custom template that I will email once per day. Here is what I have drafted:
# Standard CSV template with data in metric units
$# date, time, temperature[C], max daily temp [C], min daily temp [C], max daily humidity[%], rainfall[mm], leaf wetness [0-15],
[YYYY]-[MM]-[DD],[hh]:[mm],[th0temp-avg.1:],[th0temp-dmax.1:-],[th0temp-dmin.1:-],[th0hum-max.1:],[rain0total-sum.1:],[th15hum-max.1:]
I know this is broken so looking for help to fix the max and min temp reporting. Also does the leaf wetness look right assuming th15 is the correct sensor? The leaf sensor has a range of 0 to 15 where 0 is dry and 15 fully wet. I would also like to calculate how long every day the leaf was wet, ie. anything above 0 and in the range 1 to 15..
Final question, can I add a new template or just modify an existing template. I did duplicate and rename the template, but it doesn't appear in the 'add service event' as an option to use.
I'd appreciate any help.
Gary
Re: Template errors/advice
Are you using the template for generating export files with a Meteobridge PRO?
Is the third and fourth line separated by a "newline"? One can't see that from the way you pasted it in.
You can find the sensor annotation when moving the cursor into the sensors of the historical section on "Live Data" page. There you see names hoovering.
There is no counting of certain sensor thresholds, but your follow on processes might do when evaluating the resulting CSV file.
