Setup for SFTP
AlVista
Setup for SFTP
Post by AlVista »
Hi, i am trying to set up sftp to allow Meteobridge Pro to send template-based reports to my iMac, which is running High Sierra, and is on the same local network as the Meteobridge. I can see the Meteobridge screen in my browser, and remorte access via ssh and sftp are running on the Mac for all users. I have entered the IP address of the Mac (192.168.1.10, which is static), my username and password, and a folder location in the form "/Users/iMac/Documents/Weather". However, I just get an error message saying "Error: SFTP test upload failed: Couldn't read packet: Connection reset by peer". Can you tell me where I am going wrong, please?
Re: Setup for SFTP
Please post screen dumps of the settings you use. The error will be in there.
AlVista
Re: Setup for SFTP
Post by AlVista »
Here's the attachment I get after pressing Save then Test SFTP
Screen Shot 2018-04-02 at 08.34.26.png (297.79 KiB) Viewed 2918 times
Re: Setup for SFTP
SFTP on port 21 is not a great idea ;-)
AlVista
Re: Setup for SFTP
Post by AlVista »
I am interested in weather, not computers! You may not realise how little some of your users know about these settings, and indeed how incomplete are your published instructions!
So if port 21 (the default) is not a good idea, is it the cause of the failure, and what would be a good idea?
Re: Setup for SFTP
Standard port for FTP is 21, for SSH and SFTP (which is a protocol based on SSH) it is 22.
Google would have told you on first try ;-)
https://serverfault.com/questions/74176 ... s-sftp-use
