Can't access meteobridge online **solved**
redeye
Post by redeye »
My WS (vantage vue) is working, uploading to WU, WOW & Weathercloud but Cumulus shows Error 32701 and won't start up....so l try and access my MB and nothing comes up, only "this site cant be reached......err_connection_timed_out"
How do l get going again?
Re: Can't access meteobridge online
Sounds like a local network issue? Check all your cables/connections and try repowering the MB.
redeye
Post by redeye »
well, its fixed....somehow the IP address changed
redeye wrote: Sat May 12, 2018 12:00 pm well, its fixed....somehow the IP address changed
You running DHCP then? Yes it will change.
redeye
Post by redeye »
thanks Matt, yes DHCP.....how often is it going to change? a bit annoying lol
you should be able to tell your router that the device with a specific MAC gets the same IP all the time. Most routers allow that.
merlinwx
Post by merlinwx »
I have the exact same problem as redeye...unfortunately, the IP address is not the problem. Data moving along to the WX services just fine, I just can't access MB dashboard via WLAN. Ethernet access still seems to work. Any ideas what's wrong?
merlinwx
Post by merlinwx »
Problem solved. Figured it out myself, DHCP issue with WIFI extender. Meteobridge still does not appear in my DHCP client list as it did before, but I'm leaving well enough alone.
