Meteobridge pro crash
frogfoot
Post by frogfoot »
I've had the following crash a few times now, any idea what's up?
oled (03.05.2018 07:19:42): process started.
database (03.05.2018 23:31:01): process started.
wnetd (03.05.2018 23:31:03): process started.
system (03.05.2018 23:31:04): start of logging process initiated.
logger (03.05.2018 23:31:04): databases connected. Update interval 3600 seconds.
logger (03.05.2018 23:31:04): historical data loaded (0 records).
logger (03.05.2018 23:31:04): data logger (version 5.0x, build 12181) started.
logger (03.05.2018 23:31:06): connect station 0 (Meteostick Vantage via USB serial).
logger (03.05.2018 23:31:06): connect station 9 (System Data via Plug-in).
logger (03.05.2018 23:31:08): transmitter 1 registered as ISS
logger (03.05.2018 23:31:08): Meteostick Version 2.4
logger (03.05.2018 23:31:08): debug off
logger (03.05.2018 23:31:08): verbose off
logger (03.05.2018 23:31:08): output raw (8 bytes)
logger (03.05.2018 23:31:08): output raw (10 bytes)
logger (03.05.2018 23:31:08): filter on
logger (03.05.2018 23:31:08): rx threshold set to -75db
logger (03.05.2018 23:31:08): listening to transmitter 1
logger (03.05.2018 23:31:08): bandwidth narrow
logger (03.05.2018 23:31:09): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (03.05.2018 23:31:09): services paused.
logger (03.05.2018 23:31:09): chip authentication ok: 14
logger (03.05.2018 23:31:09): frequency band 868MHz (EU)
database (03.05.2018 23:31:25): database sync done (40 tables, 213/1248 writes)
logger (03.05.2018 23:32:09): sensors are now providing data.
logger (03.05.2018 23:32:09): services started.
logger (03.06.2018 12:43:43): unexpected 0 bytes.
logger (03.06.2018 12:43:43): can't set attributes of device /dev/ttyMH to former values: Input/output error
logger (03.06.2018 12:43:43): disconnect station 0 (Meteostick Vantage): response without data
logger (03.06.2018 12:44:13): can't open device /dev/ttyMH: No such file or directory
logger (03.06.2018 12:44:43): message above repeats 1 time.
system (03.06.2018 11:45:07): stop of logging process initiated.
logger (03.06.2018 12:45:07): parent process received termination signal (15).
logger (03.06.2018 12:45:07): child process received termination signal (15).
database (03.06.2018 12:45:07): process terminated normally.
test5m (03.06.2018 11:45:08): USB storage remounted: /dev/
system (03.06.2018 11:45:08): start of logging process initiated.
database (03.06.2018 12:45:09): process started.
logger (03.06.2018 12:45:09): databases connected. Update interval 3600 seconds.
logger (03.06.2018 12:45:09): historical data loaded (0 records).
logger (03.06.2018 12:45:09): data logger (version 5.0x, build 12181) started.
logger (03.06.2018 12:45:09): error while doing bind (port 5551): Address already in use
logger (03.06.2018 12:45:09): killed process "2542/sh" listening to port 5551.
database (03.06.2018 12:45:25): database sync done (40 tables, 1680/1680 writes)
logger (03.06.2018 12:45:39): databases connected. Update interval 3600 seconds.
logger (03.06.2018 12:45:39): historical data loaded (0 records).
logger (03.06.2018 12:45:39): data logger (version 5.0x, build 12181) started.
logger (03.06.2018 12:45:39): error while doing bind (port 5551): Address already in use
logger (03.06.2018 12:45:39): killed process "2543/meteosys" listening to port 5551.
logger (03.06.2018 12:46:09): databases connected. Update interval 3600 seconds.
logger (03.06.2018 12:46:09): historical data loaded (0 records).
logger (03.06.2018 12:46:09): data logger (version 5.0x, build 12181) started.
logger (03.06.2018 12:46:10): can't open device /dev/ttyMH: No such file or directory
logger (03.06.2018 12:46:10): connect station 9 (System Data via Plug-in).
logger (03.06.2018 12:46:13): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (03.06.2018 12:46:13): services paused.
logger (03.06.2018 12:46:40): can't open device /dev/ttyMH: No such file or directory
logger (03.06.2018 12:47:40): message above repeats 2 times.
logger (03.06.2018 12:48:10): give up waiting for sensors after 120 secs.
logger (03.06.2018 12:48:10): services activated.
logger (03.06.2018 12:48:10): can't open device /dev/ttyMH: No such file or directory
logger (03.06.2018 13:59:40): message above repeats 143 times.
database (03.06.2018 14:00:01): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.06.2018 14:00:01): rollback on insert forced (2) (min): data10num
database (03.06.2018 14:00:01): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.06.2018 14:00:19): rollback on insert forced (2) (min): data10num
database (03.06.2018 14:00:19): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.06.2018 14:00:19): process stopped.
test5m (03.06.2018 13:00:39): database daemon stalled, will be restarted now.
database (03.06.2018 14:00:39): process started.
logger (03.06.2018 14:00:40): can't open device /dev/ttyMH: No such file or directory
database (03.06.2018 14:00:52): database sync done (40 tables, 90/1680 writes)
logger (03.06.2018 14:01:10): can't open device /dev/ttyMH: No such file or directory
logger (03.06.2018 14:56:40): message above repeats 111 times.
frogfoot
Re: Meteobridge pro crash
Post by frogfoot »
another crash today
oled (03.06.2018 13:57:11): process started.
database (03.06.2018 14:59:21): process started.
wnetd (03.06.2018 14:59:24): process started.
system (03.06.2018 14:59:24): start of logging process initiated.
logger (03.06.2018 14:59:24): databases connected. Update interval 3600 seconds.
logger (03.06.2018 14:59:24): historical data loaded (0 records).
logger (03.06.2018 14:59:24): data logger (version 5.0x, build 12199) started.
logger (03.06.2018 14:59:27): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2018 14:59:27): connect station 9 (System Data via Plug-in).
logger (03.06.2018 14:59:30): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (03.06.2018 14:59:30): services paused.
logger (03.06.2018 14:59:31): transmitter 1 registered as ISS
logger (03.06.2018 14:59:31): Meteostick Version 2.4
logger (03.06.2018 14:59:31): debug off
logger (03.06.2018 14:59:31): verbose off
logger (03.06.2018 14:59:31): output raw (8 bytes)
logger (03.06.2018 14:59:31): output raw (10 bytes)
logger (03.06.2018 14:59:31): filter on
logger (03.06.2018 14:59:31): rx threshold set to -75db
logger (03.06.2018 14:59:31): listening to transmitter 1
logger (03.06.2018 14:59:31): bandwidth narrow
logger (03.06.2018 14:59:31): chip authentication ok: 14
logger (03.06.2018 14:59:32): frequency band 868MHz (EU)
database (03.06.2018 14:59:48): database sync done (40 tables, 157/1681 writes)
logger (03.06.2018 15:00:33): sensors are now providing data.
logger (03.06.2018 15:00:33): services started.
logger (07.06.2018 11:47:16): unexpected 0 bytes.
logger (07.06.2018 11:47:16): can't set attributes of device /dev/ttyMH to former values: Input/output error
logger (07.06.2018 11:47:16): disconnect station 0 (Meteostick Vantage): response without data
logger (07.06.2018 11:47:46): can't open device /dev/ttyMH: No such file or directory
logger (07.06.2018 11:51:16): message above repeats 7 times.
system (07.06.2018 10:51:16): stop of logging process initiated.
logger (07.06.2018 11:51:16): parent process received termination signal (15).
logger (07.06.2018 11:51:16): child process received termination signal (15).
database (07.06.2018 11:51:16): process terminated normally.
test5m (07.06.2018 10:51:18): USB storage remounted: /dev/
system (07.06.2018 10:51:18): start of logging process initiated.
database (07.06.2018 11:51:18): process started.
logger (07.06.2018 11:51:18): databases connected. Update interval 3600 seconds.
logger (07.06.2018 11:51:18): historical data loaded (0 records).
logger (07.06.2018 11:51:18): data logger (version 5.0x, build 12199) started.
logger (07.06.2018 11:51:18): error while doing bind (port 5551): Address already in use
logger (07.06.2018 11:51:18): killed process "2545/sh" listening to port 5551.
database (07.06.2018 11:51:35): database sync done (40 tables, 1720/1720 writes)
logger (07.06.2018 11:51:48): databases connected. Update interval 3600 seconds.
logger (07.06.2018 11:51:48): historical data loaded (0 records).
logger (07.06.2018 11:51:48): data logger (version 5.0x, build 12199) started.
logger (07.06.2018 11:51:48): error while doing bind (port 5551): Address already in use
logger (07.06.2018 11:51:48): killed process "2546/meteosys" listening to port 5551.
logger (07.06.2018 11:52:18): databases connected. Update interval 3600 seconds.
logger (07.06.2018 11:52:18): historical data loaded (0 records).
logger (07.06.2018 11:52:18): data logger (version 5.0x, build 12199) started.
logger (07.06.2018 11:52:19): can't open device /dev/ttyMH: No such file or directory
logger (07.06.2018 11:52:19): connect station 9 (System Data via Plug-in).
logger (07.06.2018 11:52:22): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (07.06.2018 11:52:22): services paused.
logger (07.06.2018 11:52:49): can't open device /dev/ttyMH: No such file or directory
logger (07.06.2018 11:53:49): message above repeats 2 times.
logger (07.06.2018 11:54:19): give up waiting for sensors after 120 secs.
logger (07.06.2018 11:54:19): services activated.
logger (07.06.2018 11:54:19): can't open device /dev/ttyMH: No such file or directory
logger (07.06.2018 13:59:49): message above repeats 251 times.
database (07.06.2018 14:00:00): cannot insert into data10num_hour  (after 0 tries in 3ms): database or disk is full
database (07.06.2018 14:00:00): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:00): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:01): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:01): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:01): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:02): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:02): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:02): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:03): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:03): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:03): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:04): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:04): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:04): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:05): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:05): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:05): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:06): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:06): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:06): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:07): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:07): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:07): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:08): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:08): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:08): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:09): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:09): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:09): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:10): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:10): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:10): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:11): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:11): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:11): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:12): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:12): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:12): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:13): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:13): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:13): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:14): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:14): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:14): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:15): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:15): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:15): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:16): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:16): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:16): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:17): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:17): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:17): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (07.06.2018 14:00:18): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (07.06.2018 14:00:18): rollback on insert forced (2) (min): data10num
database (07.06.2018 14:00:18): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
logger (07.06.2018 14:00:19): can't open device /dev/ttyMH: No such file or directory
database (07.06.2018 14:00:19): process stopped.
logger (07.06.2018 14:00:49): can't open device /dev/ttyMH: No such file or directory
test5m (07.06.2018 13:00:51): database daemon stalled, will be restarted now.
database (07.06.2018 14:00:51): process started.
database (07.06.2018 14:01:05): database sync done (40 tables, 88/1703 writes)
logger (07.06.2018 14:01:19): can't open device /dev/ttyMH: No such file or directory
logger (07.06.2018 19:01:19): message above repeats 600 times.
Anyone?
Can you please give me remote access? I want to check if it is a USB storage problem.
frogfoot
Post by frogfoot »
email sent
frogfoot
Post by frogfoot »
Problem is still happening ... Todays log
database (20.06.2018 08:00:07): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 08:00:07): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 08:00:07): rollback on insert forced (2) (min): data10num
database (20.06.2018 08:00:08): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 08:00:08): rollback on insert forced (2) (min): data10num
database (20.06.2018 08:00:08): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 08:00:09): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 08:00:09): rollback on insert forced (2) (min): data10num
database (20.06.2018 08:00:09): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 08:00:10): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 08:00:10): rollback on insert forced (2) (min): data10num
database (20.06.2018 08:00:10): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 08:00:11): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 08:00:11): rollback on insert forced (2) (min): data10num
database (20.06.2018 08:00:11): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 08:00:12): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 08:00:12): rollback on insert forced (2) (min): data10num
database (20.06.2018 08:00:12): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 08:00:13): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 08:00:13): rollback on insert forced (2) (min): data10num
database (20.06.2018 08:00:13): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 08:00:14): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 08:00:14): rollback on insert forced (2) (min): data10num
database (20.06.2018 08:00:14): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 08:00:15): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 08:00:15): rollback on insert forced (2) (min): data10num
database (20.06.2018 08:00:15): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 08:00:16): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 08:00:16): rollback on insert forced (2) (min): data10num
database (20.06.2018 08:00:16): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 08:00:17): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 08:00:17): rollback on insert forced (2) (min): data10num
database (20.06.2018 08:00:17): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 08:00:18): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 08:00:18): rollback on insert forced (2) (min): data10num
database (20.06.2018 08:00:18): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 08:00:19): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 08:00:19): rollback on insert forced (2) (min): data10num
database (20.06.2018 08:00:19): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 08:00:20): process stopped.
logger (20.06.2018 08:00:23): can't open device /dev/ttyMH: No such file or directory
logger (20.06.2018 08:01:23): message above repeats 2 times.
test5m (20.06.2018 07:01:31): database daemon stalled, will be restarted now.
database (20.06.2018 08:01:31): process started.
database (20.06.2018 08:01:45): database sync done (40 tables, 92/1720 writes)
logger (20.06.2018 08:01:53): can't open device /dev/ttyMH: No such file or directory
logger (20.06.2018 13:59:53): message above repeats 716 times.
database (20.06.2018 14:00:01): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:01): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:01): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:02): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:02): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:02): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:03): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:03): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:03): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:04): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:04): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:04): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:05): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:05): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:05): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:05): cannot insert into data10num_hour  (after 0 tries in 2ms): database or disk is full
database (20.06.2018 14:00:06): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:06): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:06): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:07): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:07): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:07): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:08): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:08): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:08): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:09): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:09): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:09): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:10): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:10): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:10): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:11): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:11): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:11): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:12): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:12): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:12): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:13): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:13): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:13): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:14): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:14): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:14): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:15): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:15): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:15): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:16): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:16): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:16): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:17): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:17): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:17): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:18): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:18): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:18): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (20.06.2018 14:00:19): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (20.06.2018 14:00:19): rollback on insert forced (2) (min): data10num
database (20.06.2018 14:00:19): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
Can you please sent me login credentials again? How did we solve the problem last time?
frogfoot
Post by frogfoot »
email sent again
