No valid Theme found **solved**
bedwyr
Post by bedwyr »
When I try to open Expert Mode (OpenWRT) I get an error as follows:
/usr/lib/lua/luci/dispatcher.lua:284: No valid theme found
stack traceback:
[C]: in function 'assert'
/usr/lib/lua/luci/dispatcher.lua:284: in function 'dispatch'
/usr/lib/lua/luci/dispatcher.lua:195: in function </usr/lib/lua/luci/dispatcher.lua:194>
I get the same error when trying to go to "http://ip-of-your-meteobridge/cgi-bin/fwupdate.cgi".
Currently running the latest version 3.7 on a DIR-505.
Thanks for any help you can provide.
Re: No valid Theme found
I don't recommend to use that mode. It is just in case of emergency to install a new firmware or other things. Please don't expect all features working there perfectly.
By clicking there around for fun the chance is good, that you stall the unit and will need a factory reset.
