Meteobridge Not Getting Data from ObserverIP **solved**
atlasws
Post by atlasws »
This is a brand new setup, so its very likely I made a mistake setting something up.
My ObserverIP is getting live data from the sensor array
The Meteobridge is set to pull data from the ObserverIP WS-1600
However no live data s making it over
Here's the networking information from the Meteobridge
And here's the networking information from the ObserverIP
Both pieces of hardware are plugged into the same router, an Airport Extreme, and I can see them both when I do an IP scan
Any ideas on what I'm doing wrong or suggestions to try would be appreciated. Thanks in advance.
LOBWX
Re: Meteobridge Not Getting Data from ObserverIP
Post by LOBWX »
On the second image try putting the IP addy 10.0.1.27, instead of WS-1600.
It might be just me, but you might want to obscure your MAC address next time :wink:
yes, it needs the IP inserted.
