How delete invalid value
efiten
Post by efiten »
Somehow, an invalid UV reading is logged, therefore I have a 'yearly record UV' of 15.
Can I remove this single record from the database ? Because now, I can't see the REAL UV record for my station.
Erwin
http://weather.on8ar.eu/
efiten
Re: How delete invalid value
Post by efiten »
No-one an idea how to remove this ?
Try the History tab, select which sensor & date you want to edit in the top box Inspect Stored data, down the bottom see the Edit Data box where you can delete and/or edit specific values,
