No access to Meteohub page
panosloupasis
Post by panosloupasis »
Hello
In the "Network" page of Meteohub, by accident I changed the port number from 80 to 7777 and then pressed "Save". The problem now is that I cannot access meteohub at all from my LAN! What can I do to solve this? Can Meteohub be accessed by another IP except 192.168.1.77?
Thank you!
Re: No access to Meteohub page
Is 192.168.1.77 the actual IP address? Does MeteoHub have the option to change the actual "port". If so then if you changed the default port (80) to 7777 then have you tried 192.168.1.77:7777
