Dew Point from WH-1090
doncurtis
Post by doncurtis »
On a WH-1090, I normally see dew point but once the rel humidity gets below 10% the wh-1090 console just displays dashes and in live data..... th0dew shows trashcan, which I presume means offline. However, with the humidity stretch setup... You are still showing th0hum as online.
Yet the latest reading on the live data page shows a dewpoint.
Which all leads to my question... Where do you get the dewpoint reading... From the console or from calculating the value from temp & humidity (after using the 'stretch' values setup on the station page)
And thus... If I turned off th0dew all the time, do you always just calculate it?
Don
Re: Dew Point from WH-1090
That depends on the station. in case of WH-1090 it is computed from temp and hum.
doncurtis
Post by doncurtis »
Is it calculated before or after you adjust the humidity reading based on the settings on the weather station tab where you allow the user to set the reading that equals 0% and the reading that equals 100%
Don
before.
