Dew Point from WH-1090
Posted: Tue Aug 28, 2018 9:43 pm
by doncurtis
On a WH-1090, I normally see dew point but once the rel humidity gets below 10% the wh-1090 console just displays dashes and in live data..... th0dew shows trashcan, which I presume means offline. However, with the humidity stretch setup... You are still showing th0hum as online.
Yet the latest reading on the live data page shows a dewpoint.
Which all leads to my question... Where do you get the dewpoint reading... From the console or from calculating the value from temp & humidity (after using the 'stretch' values setup on the station page)
And thus... If I turned off th0dew all the time, do you always just calculate it?
Re: Dew Point from WH-1090
Posted: Wed Aug 29, 2018 12:32 am
That depends on the station. in case of WH-1090 it is computed from temp and hum.
Posted: Wed Aug 29, 2018 1:03 am
by doncurtis
Is it calculated before or after you adjust the humidity reading based on the settings on the weather station tab where you allow the user to set the reading that equals 0% and the reading that equals 100%
Thanks!
Posted: Thu Aug 30, 2018 11:55 pm
before.
