Apologies if this is an obvious question.
Meteohub says it supports the weatherflow sensors. But I cannot figure out to set meteohub to connect to the weatherflow.
The weatherflow hub and my meteohub are both on the same wireless-lan, and the weatherflow hub is plugged into the meteohub ( a raspberry pi) via usb, the green light of the flow hub is on and it is happily uploading data to the weatherflow network.
Anybody know how to do the setup?
Best
Mike
Weatherflow
Re: Weatherflow
I guess I needed to hunt down a little farther in the list of topics. I just saw your post which didn't show up when I did a search.
I have the same issue and posted in viewtopic.php?f=61&t=13187. Hopefully we can get a resolution to this issue.
David D. Nelson
