Weatherflow Setup
Posted: Sun Sep 09, 2018 11:01 am
by Vertikar
Hi All,
Noticed that weatherflow is now supported on 5.0z, has anyone set this up yet, or is there any documentation on how to set it up?
Cheers,
Vertikar
Re: Weatherflow Setup
Posted: Wed Oct 10, 2018 2:52 am
by GizmoEV
I have the same question. I just received a used Meteobridge PRO and it isn't seeing any of my WeatherFlow station data. I did add the WeatherFlow network and my WF login credentials but no luck.
Any suggestions?
David
Posted: Wed Oct 10, 2018 9:04 am
by wvdkuil
GizmoEV wrote: Wed Oct 10, 2018 2:52 am
Any suggestions?
David
Good morning,
You are posting this question on a
Meteohub discussion. But you have a
Meteobridge Same forum, different topics. Just can take more time before someone answers.
As from release 3.4 released February 24, 2018 (check
https://www.meteobridge.com/wiki/index.php/Forum ) the WeatherFlow is
fully supported.
- You should not set "the WeatherFlow network and my WF login credentials" that is for uploading to the WF network and that is done by the WF itself.
- You should select the Weatherflow at the Weatherstation tab as in the attached screenshot.
Important: The Weatherflow AND your Meteobridge(Pro) should be on the same LAN network.
The station data is gathered from your (wireless) LAN by reading the UDP packets your WF transmits to anybody listening. And UDP can not be routed. So check your IP addresses that they are in the same range.
Posted: Thu Oct 11, 2018 12:41 am
by GizmoEV
wvdkuil wrote: Wed Oct 10, 2018 9:04 am
Thanks, I realized that after I posted. I searched for Weatherflow and Meteobridge and saw the question so replied. I created a new topic in the Mateobridge Pro section at
viewtopic.php?f=61&t=13187
