Meteobridge and WSwin
cycoso
Post by cycoso »
I do not have a datalogger in the Davis, but thanks to Meteobridge I actually have the metrics on the network.
For the storage and processing of the data, I have once looked at the software WSwin. At the beginning of the year there was a tip with a virtual LAN divider or something like that to use the data there as well. Possibly. But that was only possible if the logger is installed and you wanted to use data for WSwin and DavisNetzwerk.
Well, how can I automatically integrate the data into the software?
I hope to get a tip here.
Johannes
Meteobridge Pro, Davis Ventage Pro2
Re: Meteobridge and WSwin
When you use MB PRO RF capacity to read Davis sensor data there is no way to feed WSWIN.
If you use a Davis Logger withe the MB PRO the logger can be addressed like an Davis IP logger. But I guess your setup does not look like this.
