Hi guys,
I would like to connect my Weatherlink IP to my Meteobridge (TPLink TL-MR3020).
My problem is that I cant figure out why my live data is not working..
MB Settings:
Type of Connection: Wireless Lan
LAN Bridge: Integrate client on Meteobridge's LAN adapter into WLAN Check
IP 192.168.1.156
My MB Settings before is
Type of Connection: Wireless Lan uncheck
IP 192.168.1.156
But my WeatherlinkIP is connected via routher.. not in the MB RJ45 hub
It works.. but now I wanted to connect my weatherlinkIP via the MB Lan.. but i cant figure it out..
wnetd (21.09.2018 12:08:29): process started.
system (21.09.2018 12:08:29): start of logging process initiated.
logger (21.09.2018 12:08:29): historical data loaded (19 records).
logger (21.09.2018 12:08:29): data logger (version 5.1, build 12353) started.
logger (21.09.2018 12:08:45): error connect socket 192.168.1.156 (150): port 22222: Operation now in progress
logger (21.09.2018 12:08:48): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (21.09.2018 12:08:48): services paused.
logger (21.09.2018 12:09:15): error connect socket 192.168.1.156 (150): port 22222: Operation now in progress
logger (21.09.2018 12:10:15): message above repeats 2 times.
logger (21.09.2018 12:10:30): give up waiting for sensors after 120 secs.
logger (21.09.2018 12:10:30): services activated.
logger (21.09.2018 12:10:45): error connect socket 192.168.1.156 (150): port 22222: Operation now in progress
logger (21.09.2018 12:12:15): message above repeats 3 times.
Please Help. Thanks
Integrate client on Meteobridge's LAN adapter into WLAN not working
- 519C7028-6A73-44E1-AF66-8918C10F61F3.jpeg (204.63 KiB) Viewed 2048 times
- 33CD6ED8-758F-4FC5-BBC9-0B9B58459556.png (264.33 KiB) Viewed 2051 times
- F602B9C0-E2A6-4D08-8CA7-5E34AE0B286A.png (192.11 KiB) Viewed 2051 times
Re: Integrate client on Meteobridge's LAN adapter into WLAN not working
Can you post a screen shot of your Weather Station page?
see attached file.. thanks
- Screen Shot 2018-09-21 at 11.44.19 PM copy.png (419.35 KiB) Viewed 2036 times
- Screen Shot 2018-09-21 at 11.44.28 PM.png (352.16 KiB) Viewed 2037 times
Thank you sir
- Screen Shot 2018-09-21 at 11.57.49 PM copy.png (445.31 KiB) Viewed 2034 times
It was just a thought if it is using DHCP and may have changed? Is your WLIP fixed or DHCP?
Im using Fixed IP in my WeatherLinkIP.
192.168.1.156
192.168.1.156
