Error: Finger print of application
Has anybody seen this error?
Error: Finger print of application and system do not match
Re: Error: Finger print of application
Does it show that on a system that is marked as using beta code? Will be shown in the headline on "system" tab.
Apart from that I don't really have an explanation. Did you try a reboot?
When you give me a remote login, I can check what did go wrong.
Regards,
Boris
Boris,
What I think this is all about now is a version conflict between MBPro & USB stick. This error appears to show in this case as the MBPro version based on the internal USB drive is different to a USB stick plugged to the front panel and from which the pro is then rebooted. In this case the internal version is Sep 22 and the USB stick came from a Pro running a version from July.
What I was doing was checking a USB stick out which was the internal USB drive (with July FW) from another Pro we talked about the other day.
For sure I can set this back up and give you access.
