Nano - Gust Wind
Nano - Gust Wind
I noted that the maxim recorded gust is showing the maximum wind and not the maximum gust wind. In the attached graph the max gust is over 70 km/h but the record shows only 59 km/h.
- 2018-10-07 (2).png (158.5 KiB) Viewed 2486 times
Re: Nano - Gust Wind
I don't think so. How did you feed your attached graph?
The graph is generated using the Weather34 template and the API. According to Brian he read the max values from meteobridge.
I still don't get your point. To what exactly do you see a contradiction? Why do you think the graph is not right? Where do you get the "record" of 59 to compare with?
This is wind data the template for weather34 is fed with. I don't know which of these Brian is using for the graph:
[wind0avgwind-act:--]
[wind0wind-act:--]
[wind0dir-act:--]
[wind0dir-act:--]
[wind0wind-act=bft.0:--]
[wind0chill-act:--]
[wind0avgwind-dmax:--]
[wind0avgwind-dmaxtime:--]
[wind0wind-dmax:--]
[wind0wind-dmaxtime:--]
[wind0wind-max10:--]
[wind0dir-avg10:--]
[wind0dir-avg10:--]
[wind0wind-avg15:—]
[wind0wind-avg30:—]
[wind0wind-ydmax:--]
[wind0wind-ydmaxtime:--]
[wind0wind-mmax:--]
[wind0wind-mmaxtime:--]
[wind0wind-ymax:--]
[wind0wind-ymaxtime:--]
[wind0wind-act:--]
[wind0dir-act:--]
[wind0dir-act:--]
[wind0chill-act:--]
[wind0wind-dmax:--]
[wind0dir-avg10:--]
[wind0dir-avg10:--]
[wind0wind-avg15:—]
[wind0wind-avg30:—]
[wind0wind-mmax:--]
[wind0wind-ymax:--]
