Services HTTP stopped **solved**
Manel
Post by Manel »
After upgrading the firmware to version 3.7, the HTTP service of the Meteobridge Pro has stopped, there is a red X in the Live Data tab.
I have tested the downgrade to version 3.6 and it has worked correctly again. A green V appears next to the HTTP service on the Live Data tab.
I have seen on your website that in version 3.7 of October 7, changes have been made in the handling of failures in HTTP / HTTPS transmissions.
Could it happen that these changes have caused the problem I mentioned?
Re: Services HTTP stpped
I can check this, when you give me a remote login to your MB PRO. FAQ section in the forum explains how. Please send URL and password to "info@meteobridge.com".
Manel
Post by Manel »
I just sent you an email with the information you have requested
It has turned out to be a timeout problem with a faulty script on the server side. So not something originally caused by the meteobridge.
Manel
Re: Services HTTP stopped **solved**
Post by Manel »
To close this thread, the problem was that a bad configuration of the server in terms of permissions of the files and directories, caused that the php scripts did not run correctly.
Reinstalling the server properly, everything went back to normal.
Thanks for your help
