Services HTTP stopped **solved**
Posted: Fri Oct 12, 2018 2:58 am
After upgrading the firmware to version 3.7, the HTTP service of the Meteobridge Pro has stopped, there is a red X in the Live Data tab.
I have tested the downgrade to version 3.6 and it has worked correctly again. A green V appears next to the HTTP service on the Live Data tab.
I have seen on your website that in version 3.7 of October 7, changes have been made in the handling of failures in HTTP / HTTPS transmissions.
Could it happen that these changes have caused the problem I mentioned?
