MB Pro locked-up/unreachable
GizmoEV
Post by GizmoEV »
I just discovered that my MB PRO locked up or otherwise was unreachable. I don't know how old it is since I bought it used. IIRC, it had about two years of data on it when I received it. I have two Weatherflow stations on my network which are seen by the MB pro. I discovered it wasn't working when I tried to view the one week history charts at https://admin.meteobridge.com/efbeb8326 ... D7&stop=D0 and received a message about the servers being busy. I tried the local interface and that is when I discovered it wasn't reachable. A ping of the IP gave no response. I have the display turned off so I couldn't see any messages on it. The second light from the top was lit like normal. The green light didn't blink as normal. I don't have an ethernet cable close enough to have tested it without unplugging the MB so I didn't try the wired interface.
I power cycled it and it downloaded Meteobridge 3.7 (Oct 21 2018, build 12403), FW 1.4. I looked through the logs but not sure what to look for to determine what went wrong. There is about an hour gap in the data as can be seen on 20 October 2018.
David D. Nelson
