Failed to connect to MYSQL database: Can't connect to MySQL server on 'IP' (146) **solved**
Posted: Fri Oct 26, 2018 4:49 am
by rmccullough
I followed these directions to get the database and table configured. Which seems to have gone fine.
But when I enter the details in my Meteobridge I get the error in the attached screenshot. The details I entered are correct. I can log in to phpMyAdmin with the same credentials and view the table just fine.
Re: Failed to connect to MYSQL database: Can't connect to MySQL server on 'IP' (146)
Posted: Fri Oct 26, 2018 10:57 pm
by bardek
Your database should permit remote insert for the user first and propably myslq server remote access should be enabled too.
Posted: Sun Oct 28, 2018 1:36 am
by rmccullough
bardek wrote: Fri Oct 26, 2018 10:57 pm Your database should permit remote insert for the user first and propably myslq server remote access should be enabled too.
I figured that If I could login to the phpMyAdmin interface remotely I was good to go. Had no idea that I had to allow remote access to the database itself. Working perfect now.
