Meteohub Update 2.5a and USB Stick Images 2.5a
What's hot...
Update 2.5a fixes a bug that prevents the "myweb" folder of USB stick image 2.5 to be used and provides the code for the language pack update that can now easily be installed by file-based install of "/root/locale.upd".
USB stick images 2.5a have the language pack already installed and the "myweb" bug fixed.
2GB USB stick image: http://www.meteohub.de/joomla/index.php ... &Itemid=29
4GB USB stick image: http://www.meteohub.de/joomla/index.php ... &Itemid=29
Re:Meteohub Update 2.5a and USB Stick Images 2.5a
To perform update 2.5a on versions before 2.5, please first update to 2.5, then as a next step to 2.5a.
All coming updates will need update 2.5 installed.
Frits
Post by Frits »
Boris,
I have succesfully updated to V2.5 B) , but I have now a problem with the next step: Update to V2.5a.
Option: Software Update (File) /data/transfer/update-v2.5a.upd
Message: File "/data/transfer/update-v2.5a.upd" successfully transferred. Error: Update cannot be extracted or installed.:S
What is going wrong? I have already rebooted and tried agian, but with the same result. Do you have a solution?
Frits
PS The upload tot www.HetWeerActueel.nl is OK! Thanks!
Just fixed that bug in update 2.5a. should install now fine.
Diet
Post by Diet »
Hi!
Still problems with update:
"Update erfolgreich geladen.
Update nicht installiert (inkompatible Version)."
Could you please check it again - thanks!
Didi
yep, web-based install was still not updated. fixed that. should work now also with web-based update.
peteroi
Post by peteroi »
Hi Boris,
ist das in Ordnung, daß die Update-Dateil für 2.5a nur 156kB groß ist ???
VG Peter
Pi/TE923
Diet
Post by Diet »
works fine - thanks!
Didi
Post by skyewright »
admin wrote:yep, web-based install was still not updated. fixed that. should work now also with web-based update.
Updating from 2.5 with web-based install I had the "Incompatible version thing too". Downloaded a fresh 2.5a update. That went in fine - but the System Info page still shows "Version 2.5".
Is that right?
Chill
Post by Chill »
Version 2.5a shows 2.5 in my system ... too.
While working on 2.5b with weatherlinkIP support I noticed that 2.5a doesn't install as expected. Sorry for the confusion.
2.5b fixes all this.
admin wrote:2.5b fixes all this.
2.5b now installed, and reporting itself as 2.5b :)
dc9lk
Post by dc9lk »
mhmmm to all...
i've got a v 2.5b with the help of a yesterday 2.5a-stick.
but...now there is the former rekursive myweb/update,
myweb/update again, meanwhile with a hell lot of 81 directories.
Could you please check that please, or is it only on my machine?!
73 de Günter / DC9LK
will check the 2.a usb stick image.
Are you familiar with ssh to repair this?
please tell me the outcome of these commands:
"ls -la /srv/www"
"ls -la /srv/www/myweb"
"ls -la /data/myweb"
"ls -la /data/myweb/update"
Regards,
Boris
dc9lk
Post by dc9lk »
Hi, Boris and sri for the delay...
First of all i had to find my good old putty, these are the results:
root@wxstation:~$ ls -la /srv/www
total 538
drwxr-xr-x 4 root root 1024 Jul 4 18:06 .
drwxr-xr-x 3 root root 1024 Mar 1 21:44 ..
-rw-r--r-- 1 root root 102 Aug 15 2007 admin.html
drwxr-xr-x 2 root root 1024 Mar 4 11:15 cgi-bin
-rwxr--r-- 1 root root 983 Jul 2 23:06 dashboard.html
-rwxr--r-- 1 root root 105429 Jul 2 23:06 dashboard.swf
drwxr-xr-x 2 root root 1024 Oct 3 2007 htdocs
-rw-r--r-- 1 root root 102 Nov 28 2007 index.html
-rwxr-xr-x 1 root root 14614 Mar 4 10:40 meteocam.cgi
-rwxr-xr-x 1 root root 156904 Jul 2 23:06 meteograph.cgi
-rwxr-xr-x 1 root root 108149 Jul 2 23:06 meteohtml.cgi
-rwxr-xr-x 1 root root 151424 Jul 2 23:06 meteolog.cgi
lrwxrwxrwx 1 root root 11 Jul 4 18:06 myweb -> /data/myweb
root@wxstation:~$ ls -la /srv/www/myweb
lrwxrwxrwx 1 root root 11 Jul 4 18:06 /srv/www/myweb -> /data/myweb
root@wxstation:~$ ls -la /data/myweb
total 16
drwxr-xr-x 3 root root 4096 Jul 6 18:15 .
drwxr-xr-x 10 root root 4096 Jul 4 20:09 ..
-rwxr--r-- 1 root root 996 Mar 17 16:47 index.html
lrwxrwxrwx 1 root root 11 Jul 6 18:15 myweb -> /data/myweb
drwxr-xr-x 2 root root 4096 Jul 6 20:33 uploads
root@wxstation:~$ ls -la /data/myweb/update
ls: /data/myweb/update: No such file or directory
i’m not realy sure what the meanings are, is it ok for me to install
the version 2.5c over it, or won’t it solve the problem?
Have a nice day and a big „thank you“ for your service...
I realy do like meteohub!
