Carriage return in Twitter Service
WessexWeather
Post by WessexWeather »
Hi, I’ve got a perfect Twitter Service string set up, except for one thing...
Can anyone tell me how to insert a carriage return into the string, so that information within the tweet is separated into separate lines? Twitter now supports this but I cannot figure out how to add it to the string.
This is now my tweets currently look: -
11:30 #Wimborne, #Dorset, 29m • Sunrise 07:41 • Sunset 16:10 • Temp 8.2°C • Max 8.2°C at 11:29 • Min 2.1°C at 03:19 • Pressure 1014.9mb (ST) • Wind 4.0mph N • Gust 11.0mph at 10:34 • Humidity 77﹪ • DP 4.4°C • Rain 0.0mm • http://bit.ly/1TeCMBi
Any advice much appreciated.
Simon
Re: Carriage return in Twitter Service
Did you try "\n" and "\\n" or "\n\r" and "\\n\\r"?
WessexWeather
Yes I’ve tried all those combinations, which seem to stop the auto tweets from posting at all.
Simon
pb2rdf
Post by pb2rdf »
hello admin,
Any solution yet for making possible to send tweets with more lines?
ie :
#WeatherReport [hh]:[mm] Temp: [th0temp-act]/[th0temp-dmax]/[th0temp-dmin]°C Rain: [rain0total-dmax]/[rain0total-mmax]/[rain0total-ymax]mm Wind: [wind0wind-act]/[wind0wind-dmax]m/s [wind0dir-act=nldir] Baro: [thb0press-act]hPa RH: [th0hum-act.ab:--] Sun: [sol0rad-act.ab:---]/[sol0rad-dmax.abc:---]Wm2 UV: [uv0index-act.a:-]/[uv0index-dmax.a:-]
Has this result :
#WeatherReport 00:21
Temp: 8.5/8.6/8.5°C
Rain: 0.0/17.0/540.4mm
Wind: 2.2/3.6m/s NW
Baro: 1008.0hPa
RH: 90
Sun: 0/0Wm2
UV: 0/0
Thanks in advance.
regards, Peter
Pebblebacon
Post by Pebblebacon »
Any further update?
ConligWX
Post by ConligWX »
Pebblebacon wrote: Wed Aug 21, 2019 5:46 am Any further update?
have you tried using unicode? only issue is amount of characters on the tweet.
https://developer.twitter.com/en/docs/b ... cters.html
LF = U+000A
CR = U+000D
have you tried that? dont know if it works, but worth a try since Twitter mentions unicode.
Pebblebacon
I have not. I know nothing of Unicode and haven't the slightest idea how to incorporate any of those option into #if##then##else##fi# structure.
Pebblebacon
No go.
