Twitter Templates. **solved**
ConligWX
Post by ConligWX »
Hi.
just thought I'd share my Twitter Template for anyone that wants it. set at "after every full hour"
Time: [hh]:[mm] • #Conlig, #Bangor • Temp: [th0temp-act:--]°C • Wind: [wind0dir-act=endir:---] [wind0wind-act=mph.1:--] to [wind0wind-max10=mph.1:--]mph • Pressure: [thb0press-act:--]hPa • Rain: [rain0total-sumday]mm • Hum [th0hum-act.0=:--]% • Solar: [sol0rad-act:--]W/m² •  UV Index: [uv0index-act:--]  • Sunrise: [mbsystem-sunrise:--] • Sunset: [mbsystem-sunset:--] •
Time: 12:00 • #Conlig, #Bangor • Temp: 7.5°C • Wind: 2.9 to 8.1mph W • Pressure: 1005.2hPa • Rain: 0.0mm • Hum 85% • Solar: 60.0W/m² • UV Index: 0.0 • Sunrise: 08:33 • Sunset: 15:57 •
Forecast is just the plain Davis one which is posted every 6 Hours:
#Conlig, #Bangor, Forecast at Time: [hh]:[mm] • [forecast-text]
#Conlig, #Bangor, Forecast at Time: 12:00 • Partly cloudy and cooler.
hope this helps someone.
Please share your own Template Message for Twitter too!
WA4OPQ
Location: Tennessee, USA About 40 miles west of Nashville y'all.
Re: Twitter Templates.
Post by WA4OPQ »
Here's my 7PM summary:
[MMM] [DD] - High and lows for Centerville, just west of the town square, are #if# {*105 - [th0temp-dmax=F.1:0] *} #then# [th0temp-dmax=F.1:--]º #else# [th0temp-dmax.1:--]º #fi#and [th0temp-dmin=F.1:--]º F. #if# {*([rain0total-daysum=in.2:0] > .02)*} #then#Today's rainfall: [rain0total-daysum=in.2:0] inches #else# https://t.co/9EXJdgeXZS#fi#
Dec 06 - High and lows for Centerville, just west of the town square, are 46.4º and 23.2º F. https://www.wunderground.com/personal-w ... =KTNCENTE3
or
Dec 09 - High and lows for Centerville, just west of the town square, are 34.9º and 32.9º F. Today's rainfall: 0.20 inches
ConligWX
Post by ConligWX »
Just updated my to include Cloudbase height and ET too:
Time: [hh]:[mm] • Temp: [th0temp-act:--]°C • Wind: [wind0dir-act=endir:---] [wind0wind-act=mph.1:--] to [wind0wind-max10=mph.1:--]mph • Pressure: [thb0press-act:--]hPa • Rain: [rain0total-sumday]mm • Hum: [th0hum-act.0=:--]% • ET: [sol0evo-act.1=:--]mm • Solar: [sol0rad-act:--]W/m² • UV Index: [uv0index-act:--] • Sunrise: [mbsystem-sunrise:--] • Sunset: [mbsystem-sunset:--] • Cloudbase: #if#[th0temp-act.1:0.0]>[th0dew-act.1:0.0]#then#{*([th0temp-act.1:0.0]-[th0dew-act.1:0.0])*400*0}#else#0#fi#ft • #Conlig, #Bangor •
View now looks like this:
kds
Post by kds »
After some inspiration by ConligWX, here's my template:
It's currently [th0temp-act=F.1:--]° outside#if# {*([wind0chill-act=F.1:--] < [th0temp-act=F.1:--])*} #then# with a wind chill of [wind0chill-act=F.1:--]°#else##fi##if#{*([th0heatindex-act=F.1:--] > [th0temp-act=F.1:--])*} #then# with a heat index of [th0heatindex-act=F.1:--]°#else##fi#. #if#{*([wind0wind-hmax=mph.1:--] > 0)*}#then#Wind is [wind0wind-havg=mph.1]mph from from the [wind0dir-havg=endir] with gusts up to [wind0wind-hmax=mph.1:--]mph.#else##fi# #if# {*([rain0total-daysum=in.2:0] > .02)*} #then#It has rained [rain0total-hoursum=in.2]in in the past hour, [rain0total-sumday=in.2]in total today. #else# #fi#
Here are the conditions:
  • it will always show temp.
  • if the wind chill is less than the temp, show wind chill.
  • if the heat index is greater than the temp, show heat index.
  • if the wind is gusting to greater than 0mph, then show wind speed, gust, and direction.
  • if it has rained more than .02" in the day, then show total rainfall and rainfall rate for the past hour (it tweets hourly).
ConligWX
Post by ConligWX »
Thanks for the post.
ConligWX
Post by ConligWX »
Updated mine:
Time: [hh]:[mm] • Temp: [th0temp-act:--]°C • Wind: [wind0dir-act=endir:---] [wind0wind-act=mph.1:--] to [wind0wind-max10=mph.1:--]mph • Pressure: [thb0press-act:--]hPa • Rain: [rain0total-sumday]mm • Hum: [th0hum-act.0=:--]% • ET: [sol0evo-act.1=:--]mm • Solar: [sol0rad-act:--]W/m² • UV Index: [uv0index-act:--] • Sunrise: [mbsystem-sunrise:--] • Sunset: [mbsystem-sunset:--] • Cloudbase: #if#[th0temp-act.1:0.0]>[th0dew-act.1:0.0]#then#{*([th0temp-act.1:0.0]-[th0dew-act.1:0.0])*400*0}#else#0#fi#ft • #Conlig, #Bangor • bit.ly/2TzKYFb •
Time: 12:00 • Temp: 13.2°C • Wind: W 2.0 to 6.9mph • Pressure: 992.9hPa • Rain: 0.0mm • Hum: 82% • ET: 0.3mm • Solar: 142.0W/m² • UV Index: 0.7 • Sunrise: 05:55 • Sunset: 20:46 • Cloudbase: 1200ft • #Conlig, #Bangor • http://bit.ly/2TzKYFb •
BigSkyWeather
Post by BigSkyWeather »
kds wrote: Mon Feb 18, 2019 3:50 am After some inspiration by ConligWX, here's my template:
Thank you for sharing this code. I've implemented it in my hourly tweet reporting but I'm having an issue with the rainfall. This is what is outputs:
Conditions at 12:00 PM - 30.4°F outside with a wind chill of 25.7°F. It has rained [rain0total-hoursum=in.2]in in the past hour, 0.03in total today.
Any ideas what's wrong? I've copied your code verbatim and there's no extra characters/spaces/etc. that might have accidentally made its way in.
Thanks in advance for any help you (or anyone else) can give.
PSJohn
Post by PSJohn »
BigSkyWeather wrote: Thu Feb 27, 2020 5:40 pm
I'm receiving the same results when posting hourly. I'm assuming it is because the hourly rain resets at the top of the hour so there is no data yet. I could be wrong on this and waiting response from someone that knows.
Also tried posting at 45 after the hour, it works but then I wonder if the above is true that is it only pulling the data from minute 1 to 45 each hour?
UPDATE: I changed the interval to "before every full hour" and it is now working without any issues!
https://desertweather.com
Palm Springs, California
https://lakehemetweather.com
Lake Hemet, California
I think the explanation that when no rain information has yet been recorded for the current hour, then "[rain0total-hoursum=in.2]" might not be evaluated because of no data. when you change to "[rain0total-hoursum=in.2:0]" you should be fine. Sensor data should always be given a default reply in case no data there.
