Unable to access Nano sd dashboard with Firefox **Solved**
stewart45
Post by stewart45 »
this morning I tried to access the dashboard and all I get is a black screen with meteobridge in white in the top left hand corner tried an external login same problem, should I reboot the device, thought I'd better check with those more knowledgeable before taking the plunge, the nano is showing a solid red light, data is being feed to my website and IP is unchanged
* UPDATE* appears to be a Firefox browser problem, flushed the cash but problem still persists, works ok on Chrome and other browsers
Re: Unable to access Nano sd dashboard with Firefox
Which Firefox version on which OS did you try with?
stewart45
Post by stewart45 »
Re-installed Firefox, problem solved
