FTP WDL files.
ConligWX
FTP WDL files.
Post by ConligWX »
Hi. New to this Meteobridge and just wanted to clarify that the Weather-Display ClientRaw Parser site shows the same issues I see.
goto: https://www.tnetweather.com/wdparserold/index.php
enter your website url that have the FTP WDL files in them.
Data from Clientraw.txt = Note: Your WD Files are shorter than newer versions
Data from Clientrawdaily.txt = Note: Your WD Files are shorter than newer versions
Data from Clientrawhour.txt = Note: Your WD Files are shorter than newer versions
Data from Clientrawextra.txt = seems to be correct.
does anyone else see the same issues with these 3 files?
I know it maybe just cosmetic and not affect most, but just curious as to what data is missing.
https://saratoga-weather.org/wdparser.php
shown no errors so not sure which one is correct/newer
Re: FTP WDL files.
The clientraw files were 100% designed to fit the purpose of the "weather display" program and imho grew to a total mess over time. There are hundreds of values just blank separated in each of the 4 files. Meteobridge does not support all of its fields and may be does not cope with the very latest additions.
Looking for perfection in this area will disappoint you for sure ;-)
