Control WU Data on Error
LAWx
Post by LAWx »
Last night something happened (still don't know what) to cause the Meteobridge to record the following for about 45 minutes:
Bad th0(0) sensor data, "humidity" (255) out of range [0:100]
The bigger problem is that Meteobridge sent 0°F to WeatherUnderground for temperature and humidity values rather than declining to send data, or sending something more obviously an error. Is there a way to correct this behavior?
Re: Control WU Data on Error
You would be looking then at the condition of your Humidity and/or Temp sensor/s, maybe telling you they are starting to fail? What type of station is this?
