Page 1 of 2
MB restarts when a backup is made **solved**
Posted: Sun Dec 30, 2018 12:33 pm
by BeBe
When I do a backup the Meteobridghe Pro often makes a spontaneous reboot without making a backup. Sometimes the backup works well, both manually and periodically.
I activated the script to do a back-up each new day.
Schermafbeelding 2018-12-30 om 09.05.34.jpg (30.74 KiB) Viewed 6789 times
Log:
oled (28.12.2018 23:02:15): process started.
database (30.12.2018 00:01:54): process started.
database (30.12.2018 00:01:54): Content of RAM database restored.
database (30.12.2018 00:01:54): database sync done (0 tables, 0/0 writes).
wnetd (30.12.2018 00:01:57): process started.
system (30.12.2018 00:01:57): start of logging process initiated.
logger (30.12.2018 00:01:57): databases connected. Update interval 3600 seconds.
logger (30.12.2018 00:01:57): data logger (version 5.1a, build 12614) started.
logger (30.12.2018 00:01:59): connect station 0 (Meteostick Vantage via USB serial).
logger (30.12.2018 00:01:59): connect station 9 (System Data via Plug-in).
logger (30.12.2018 00:02:02): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (30.12.2018 00:02:02): services paused.
logger (30.12.2018 00:02:03): transmitter 1 registered as ISS
logger (30.12.2018 00:02:03): transmitter 2 registered as Wind
logger (30.12.2018 00:02:03): transmitter 3 registered as Temperature
logger (30.12.2018 00:02:03): transmitter 4 registered as Temperature
logger (30.12.2018 00:02:03): Meteostick Version 2.5.1
logger (30.12.2018 00:02:03): debug off
logger (30.12.2018 00:02:03): verbose off
logger (30.12.2018 00:02:03): output raw (8 bytes)
logger (30.12.2018 00:02:03): output raw (10 bytes)
logger (30.12.2018 00:02:03): filter on
logger (30.12.2018 00:02:04): rx threshold set to -90db
logger (30.12.2018 00:02:04): listening to transmitter 1 2 3 4
logger (30.12.2018 00:02:04): bandwidth narrow
logger (30.12.2018 00:02:04): chip authentication ok: 14
logger (30.12.2018 00:02:04): frequency band 868MHz (EU)
system (30.12.2018 00:02:05): stop of logging process initiated.
logger (30.12.2018 00:02:05): parent process received termination signal (15).
logger (30.12.2018 00:02:05): child process received termination signal (15).
database (30.12.2018 00:02:05): process terminated normally.
test5m (30.12.2018 00:02:05): USB storage remounted: /dev/sda
database (30.12.2018 00:02:06): process started.
system (30.12.2018 00:02:06): start of logging process initiated.
logger (30.12.2018 00:02:06): databases connected. Update interval 3600 seconds.
logger (30.12.2018 00:02:06): data logger (version 5.1a, build 12614) started.
logger (30.12.2018 00:02:06): error while doing bind (port 5551): Address already in use
logger (30.12.2018 00:02:06): killed process "2761/sh" listening to port 5551.
database (30.12.2018 00:02:06): database sync done (0 tables, 0/0 writes).
logger (30.12.2018 00:02:37): databases connected. Update interval 3600 seconds.
logger (30.12.2018 00:02:37): data logger (version 5.1a, build 12614) started.
logger (30.12.2018 00:02:37): error while doing bind (port 5551): Address already in use
logger (30.12.2018 00:02:37): killed process "2763/meteosys" listening to port 5551.
logger (30.12.2018 00:03:07): databases connected. Update interval 3600 seconds.
logger (30.12.2018 00:03:07): data logger (version 5.1a, build 12614) started.
logger (30.12.2018 00:03:07): connect station 0 (Meteostick Vantage via USB serial).
logger (30.12.2018 00:03:07): connect station 9 (System Data via Plug-in).
logger (30.12.2018 00:03:08): transmitter 1 registered as ISS
logger (30.12.2018 00:03:08): transmitter 2 registered as Wind
logger (30.12.2018 00:03:08): transmitter 3 registered as Temperature
logger (30.12.2018 00:03:08): transmitter 4 registered as Temperature
logger (30.12.2018 00:03:08): Meteostick Version 2.5.1
logger (30.12.2018 00:03:08): debug off
logger (30.12.2018 00:03:08): verbose off
logger (30.12.2018 00:03:08): output raw (8 bytes)
logger (30.12.2018 00:03:08): output raw (10 bytes)
logger (30.12.2018 00:03:08): filter on
logger (30.12.2018 00:03:08): rx threshold set to -90db
logger (30.12.2018 00:03:08): listening to transmitter 1 2 3 4
logger (30.12.2018 00:03:08): bandwidth narrow
logger (30.12.2018 00:03:08): chip authentication ok: 14
logger (30.12.2018 00:03:08): frequency band 868MHz (EU)
logger (30.12.2018 00:03:10): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (30.12.2018 00:03:10): services paused.
logger (30.12.2018 00:05:09): give up waiting for sensors after 120 secs.
logger (30.12.2018 00:05:09): services activated.
At the last manual back-up the log MB gave ’media size is 28,8G (28,7G free)’. USB-info: capacity 30,95 GB; Available 30,78 GB free.
Schermafbeelding 2018-12-30 om 09.44.23.jpg (11.58 KiB) Viewed 6789 times
Schermafbeelding 2018-12-30 om 09.48.51.jpg (20.22 KiB) Viewed 6789 times
The backup of last night on usb is 504 KB; the backups before are approx 25 Mb.
The problem occurs after the MB has been repaired in November after the MB Pro crashed at a reboot
Regards.
Re: MB restarts when a backup is made
Posted: Mon Jan 14, 2019 10:28 am
by BeBe
My MB pro reboots every time it receives a backup command. I activated the backup script on the tab system; every time the MB pro does a reboot and not a backup.
Schermafbeelding 2019-01-14 om 09.13.14.jpg (29.58 KiB) Viewed 6719 times
database (14.01.2019 00:02:20): process started.
database (14.01.2019 00:02:20): Content of RAM database restored.
database (14.01.2019 00:02:20): database sync done (0 tables, 0/0 writes).
wnetd (14.01.2019 00:02:23): process started.
system (14.01.2019 00:02:23): start of logging process initiated.
logger (14.01.2019 00:02:23): databases connected. Update interval 3600 seconds.
logger (14.01.2019 00:02:23): data logger (version 5.1a, build 12693) started.
logger (14.01.2019 00:02:25): connect station 0 (Meteostick Vantage via USB serial).
logger (14.01.2019 00:02:25): connect station 9 (System Data via Plug-in).
logger (14.01.2019 00:02:28): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.01.2019 00:02:28): services paused.
logger (14.01.2019 00:02:29): transmitter 1 registered as ISS
logger (14.01.2019 00:02:29): transmitter 2 registered as Wind
logger (14.01.2019 00:02:29): transmitter 3 registered as Temperature
logger (14.01.2019 00:02:29): transmitter 4 registered as Temperature
logger (14.01.2019 00:02:29): Meteostick Version 2.5.1
logger (14.01.2019 00:02:29): debug off
logger (14.01.2019 00:02:29): verbose off
logger (14.01.2019 00:02:29): output raw (8 bytes)
logger (14.01.2019 00:02:29): output raw (10 bytes)
logger (14.01.2019 00:02:29): filter on
logger (14.01.2019 00:02:29): rx threshold set to -90db
logger (14.01.2019 00:02:29): listening to transmitter 1 2 3 4
logger (14.01.2019 00:02:29): bandwidth narrow
logger (14.01.2019 00:02:29): chip authentication ok: 14
logger (14.01.2019 00:02:29): frequency band 868MHz (EU)
system (14.01.2019 00:02:31): stop of logging process initiated.
logger (14.01.2019 00:02:31): parent process received termination signal (15).
logger (14.01.2019 00:02:31): child process received termination signal (15).
database (14.01.2019 00:02:31): process terminated normally.
test5m (14.01.2019 00:02:31): USB storage remounted: /dev/sda
database (14.01.2019 00:02:31): process started.
system (14.01.2019 00:02:31): start of logging process initiated.
logger (14.01.2019 00:02:32): databases connected. Update interval 3600 seconds.
logger (14.01.2019 00:02:32): data logger (version 5.1a, build 12693) started.
logger (14.01.2019 00:02:32): error while doing bind (port 5551): Address already in use
logger (14.01.2019 00:02:32): killed process "2757/sh" listening to port 5551.
database (14.01.2019 00:02:32): database sync done (0 tables, 0/0 writes).
logger (14.01.2019 00:03:02): databases connected. Update interval 3600 seconds.
logger (14.01.2019 00:03:02): data logger (version 5.1a, build 12693) started.
logger (14.01.2019 00:03:02): error while doing bind (port 5551): Address already in use
logger (14.01.2019 00:03:02): killed process "2758/meteosys" listening to port 5551.
logger (14.01.2019 00:03:32): databases connected. Update interval 3600 seconds.
logger (14.01.2019 00:03:32): data logger (version 5.1a, build 12693) started.
logger (14.01.2019 00:03:33): connect station 0 (Meteostick Vantage via USB serial).
logger (14.01.2019 00:03:33): connect station 9 (System Data via Plug-in).
logger (14.01.2019 00:03:33): transmitter 1 registered as ISS
logger (14.01.2019 00:03:33): transmitter 2 registered as Wind
logger (14.01.2019 00:03:33): transmitter 3 registered as Temperature
logger (14.01.2019 00:03:33): transmitter 4 registered as Temperature
logger (14.01.2019 00:03:33): Meteostick Version 2.5.1
logger (14.01.2019 00:03:33): debug off
logger (14.01.2019 00:03:33): verbose off
logger (14.01.2019 00:03:33): output raw (8 bytes)
logger (14.01.2019 00:03:33): output raw (10 bytes)
logger (14.01.2019 00:03:33): filter on
logger (14.01.2019 00:03:33): rx threshold set to -90db
logger (14.01.2019 00:03:33): listening to transmitter 1 2 3 4
logger (14.01.2019 00:03:33): bandwidth narrow
logger (14.01.2019 00:03:33): chip authentication ok: 14
logger (14.01.2019 00:03:33): frequency band 868MHz (EU)
logger (14.01.2019 00:03:36): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.01.2019 00:03:36): services paused.
logger (14.01.2019 00:04:34): sensors are now providing data.
logger (14.01.2019 00:04:34): services started.
Even with a manual backup, the MB does a reboot and not a backup.
How is this possible? :evil:
Schermafbeelding 2019-01-14 om 09.02.03.jpg (30.89 KiB) Viewed 6719 times
Schermafbeelding 2019-01-14 om 09.02.23.jpg (17.72 KiB) Viewed 6719 times
oled (14.01.2019 07:59:24): process started.
database (14.01.2019 09:01:04): process started.
database (14.01.2019 09:01:04): Content of RAM database restored.
database (14.01.2019 09:01:04): database sync done (0 tables, 0/0 writes).
wnetd (14.01.2019 09:01:07): process started.
system (14.01.2019 09:01:07): start of logging process initiated.
logger (14.01.2019 09:01:07): databases connected. Update interval 3600 seconds.
logger (14.01.2019 09:01:07): data logger (version 5.1a, build 12693) started.
logger (14.01.2019 09:01:09): connect station 0 (Meteostick Vantage via USB serial).
logger (14.01.2019 09:01:09): connect station 9 (System Data via Plug-in).
logger (14.01.2019 09:01:12): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.01.2019 09:01:12): services paused.
logger (14.01.2019 09:01:12): transmitter 1 registered as ISS
logger (14.01.2019 09:01:12): transmitter 2 registered as Wind
logger (14.01.2019 09:01:12): transmitter 3 registered as Temperature
logger (14.01.2019 09:01:12): transmitter 4 registered as Temperature
logger (14.01.2019 09:01:12): Meteostick Version 2.5.1
logger (14.01.2019 09:01:12): debug off
logger (14.01.2019 09:01:12): verbose off
logger (14.01.2019 09:01:12): output raw (8 bytes)
logger (14.01.2019 09:01:12): output raw (10 bytes)
logger (14.01.2019 09:01:12): filter on
logger (14.01.2019 09:01:12): rx threshold set to -90db
logger (14.01.2019 09:01:12): listening to transmitter 1 2 3 4
logger (14.01.2019 09:01:12): bandwidth narrow
logger (14.01.2019 09:01:13): chip authentication ok: 14
logger (14.01.2019 09:01:13): frequency band 868MHz (EU)
system (14.01.2019 09:01:15): stop of logging process initiated.
logger (14.01.2019 09:01:15): parent process received termination signal (15).
logger (14.01.2019 09:01:15): child process received termination signal (15).
database (14.01.2019 09:01:15): process terminated normally.
test5m (14.01.2019 09:01:15): USB storage remounted: /dev/sda
database (14.01.2019 09:01:15): process started.
system (14.01.2019 09:01:15): start of logging process initiated.
database (14.01.2019 09:01:16): database sync done (0 tables, 0/0 writes).
logger (14.01.2019 09:01:16): databases connected. Update interval 3600 seconds.
logger (14.01.2019 09:01:16): data logger (version 5.1a, build 12693) started.
logger (14.01.2019 09:01:16): error while doing bind (port 5551): Address already in use
logger (14.01.2019 09:01:16): killed process "2753/sh" listening to port 5551.
logger (14.01.2019 09:01:46): databases connected. Update interval 3600 seconds.
logger (14.01.2019 09:01:46): data logger (version 5.1a, build 12693) started.
logger (14.01.2019 09:01:46): error while doing bind (port 5551): Address already in use
logger (14.01.2019 09:01:46): killed process "2756/meteosys" listening to port 5551.
logger (14.01.2019 09:02:16): databases connected. Update interval 3600 seconds.
logger (14.01.2019 09:02:16): data logger (version 5.1a, build 12693) started.
logger (14.01.2019 09:02:16): connect station 0 (Meteostick Vantage via USB serial).
logger (14.01.2019 09:02:16): connect station 9 (System Data via Plug-in).
logger (14.01.2019 09:02:17): transmitter 1 registered as ISS
logger (14.01.2019 09:02:17): transmitter 2 registered as Wind
logger (14.01.2019 09:02:17): transmitter 3 registered as Temperature
logger (14.01.2019 09:02:17): transmitter 4 registered as Temperature
logger (14.01.2019 09:02:17): Meteostick Version 2.5.1
logger (14.01.2019 09:02:17): debug off
logger (14.01.2019 09:02:17): verbose off
logger (14.01.2019 09:02:17): output raw (8 bytes)
logger (14.01.2019 09:02:17): output raw (10 bytes)
logger (14.01.2019 09:02:17): filter on
logger (14.01.2019 09:02:17): rx threshold set to -90db
logger (14.01.2019 09:02:17): listening to transmitter 1 2 3 4
logger (14.01.2019 09:02:17): bandwidth narrow
logger (14.01.2019 09:02:17): chip authentication ok: 14
logger (14.01.2019 09:02:17): frequency band 868MHz (EU)
logger (14.01.2019 09:02:18): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (14.01.2019 09:02:18): services paused.
logger (14.01.2019 09:03:18): sensors are now providing data.
logger (14.01.2019 09:03:18): services started.
Posted: Thu Jan 17, 2019 1:21 am
There is no restart, data logging is halted during backup which is needed to avoid data inconsistencies.
Posted: Wed Mar 06, 2019 10:29 am
by BeBe
Usually a back-up does not work. When I make a backup, after about 1 minute a restart will take place and no backup will be made on usb-stick.
Sometimes a backup succeeds, usually a restart occurs. So it is difficult for me te make a backup!
Am I doing something wrong?
See logger:
oled (06.03.2019 08:03:50): process started.
database (06.03.2019 09:05:33): process started.
database (06.03.2019 09:05:33): Content of RAM database restored.
database (06.03.2019 09:05:33): database sync done (0 tables, 0/0 writes).
wnetd (06.03.2019 09:05:35): process started.
system (06.03.2019 09:05:36): start of logging process initiated.
logger (06.03.2019 09:05:36): databases connected. Update interval 3600 seconds.
logger (06.03.2019 09:05:36): data logger (version 5.1a, build 12715) started.
logger (06.03.2019 09:05:37): connect station 0 (Meteostick Vantage via USB serial).
logger (06.03.2019 09:05:38): connect station 9 (System Data via Plug-in).
logger (06.03.2019 09:05:41): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (06.03.2019 09:05:41): services paused.
logger (06.03.2019 09:05:41): transmitter 1 registered as ISS
logger (06.03.2019 09:05:41): transmitter 2 registered as Wind
logger (06.03.2019 09:05:41): transmitter 3 registered as Temperature
logger (06.03.2019 09:05:41): transmitter 4 registered as Temperature
logger (06.03.2019 09:05:41): Meteostick Version 2.5.1
logger (06.03.2019 09:05:41): debug off
logger (06.03.2019 09:05:41): verbose off
logger (06.03.2019 09:05:41): output raw (8 bytes)
logger (06.03.2019 09:05:41): output raw (10 bytes)
logger (06.03.2019 09:05:41): filter on
logger (06.03.2019 09:05:41): rx threshold set to -90db
logger (06.03.2019 09:05:41): listening to transmitter 1 2 3 4
logger (06.03.2019 09:05:41): bandwidth narrow
logger (06.03.2019 09:05:41): chip authentication ok: 14
logger (06.03.2019 09:05:41): frequency band 868MHz (EU)
system (06.03.2019 09:05:43): stop of logging process initiated.
logger (06.03.2019 09:05:43): parent process received termination signal (15).
logger (06.03.2019 09:05:43): child process received termination signal (15).
database (06.03.2019 09:05:43): process terminated normally.
test5m (06.03.2019 09:05:43): USB storage remounted: /dev/sda
database (06.03.2019 09:05:44): process started.
system (06.03.2019 09:05:44): start of logging process initiated.
database (06.03.2019 09:05:44): database sync done (0 tables, 0/0 writes).
logger (06.03.2019 09:05:44): databases connected. Update interval 3600 seconds.
logger (06.03.2019 09:05:44): data logger (version 5.1a, build 12715) started.
logger (06.03.2019 09:05:44): error while doing bind (port 5551): Address already in use
logger (06.03.2019 09:05:44): killed process "2981/sh" listening to port 5551.
logger (06.03.2019 09:06:15): databases connected. Update interval 3600 seconds.
logger (06.03.2019 09:06:15): data logger (version 5.1a, build 12715) started.
logger (06.03.2019 09:06:15): error while doing bind (port 5551): Address already in use
logger (06.03.2019 09:06:15): killed process "2982/meteosys" listening to port 5551.
Last night other problems with MB pro. Suddenly services refused.
See logger:
logger (06.03.2019 04:07:18): databases connected. Update interval 3600 seconds.
logger (06.03.2019 04:07:18): data logger (version 5.1a, build 12713) started.
logger (06.03.2019 04:07:18): error while doing bind (port 5551): Address already in use
logger (06.03.2019 04:07:18): killed process "3287/sh" listening to port 5551.
logger (06.03.2019 04:07:47): databases connected. Update interval 3600 seconds.
logger (06.03.2019 04:07:47): data logger (version 5.1a, build 12713) started.
logger (06.03.2019 04:07:47): error while doing bind (port 5551): Address already in use
logger (06.03.2019 04:07:47): killed process "3288/meteosys" listening to port 5551.
logger (06.03.2019 04:08:17): databases connected. Update interval 3600 seconds.
logger (06.03.2019 04:08:17): data logger (version 5.1a, build 12713) started.
logger (06.03.2019 04:08:18): connect station 0 (Meteostick Vantage via USB serial).
logger (06.03.2019 04:08:18): connect station 9 (System Data via Plug-in).
logger (06.03.2019 04:08:18): transmitter 1 registered as ISS
logger (06.03.2019 04:08:18): transmitter 2 registered as Wind
logger (06.03.2019 04:08:18): transmitter 3 registered as Temperature
logger (06.03.2019 04:08:18): transmitter 4 registered as Temperature
logger (06.03.2019 04:08:18): Meteostick Version 2.5.1
logger (06.03.2019 04:08:18): debug off
logger (06.03.2019 04:08:18): verbose off
logger (06.03.2019 04:08:18): output raw (8 bytes)
logger (06.03.2019 04:08:18): output raw (10 bytes)
logger (06.03.2019 04:08:18): filter on
logger (06.03.2019 04:08:18): rx threshold set to -90db
logger (06.03.2019 04:08:18): listening to transmitter 1 2 3 4
logger (06.03.2019 04:08:18): bandwidth narrow
logger (06.03.2019 04:08:18): chip authentication ok: 14
logger (06.03.2019 04:08:18): frequency band 868MHz (EU)
logger (06.03.2019 04:08:21): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (06.03.2019 04:08:21): services paused.
logger (06.03.2019 04:09:19): sensors are now providing data.
logger (06.03.2019 04:09:19): services started.
logger (06.03.2019 04:38:52): child process received timeout signal (14).
logger (06.03.2019 04:38:52): disconnect station 0 (Meteostick Vantage): exit
logger (06.03.2019 04:38:52): disconnect station 9 (System Data): exit
Posted: Wed Mar 06, 2019 2:51 pm
by ConligWX
what size are your backups - if they are successful ?
Posted: Wed Mar 06, 2019 3:44 pm
by BeBe
The last backup:
Last login: Wed Mar 6 14:41:37 on ttys000
You have mail.
/Volumes/MB_BACK-UP/dbase-201902181957 ; exit;
iMac-van-xxxxxxxxxxxxxx /Volumes/MB_BACK-UP/dbase-201902181957 ; exit;
-bash: /Volumes/MB_BACK-UP/dbase-201902181957: cannot execute binary file
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Proces voltooid]
Posted: Wed Mar 06, 2019 6:28 pm
by ConligWX
is there enough space on the partition? or perhaps the drive is corrupt?
Posted: Wed Mar 06, 2019 10:08 pm
by BeBe
Yes, there is enough space. I made a new back-up with another usb stick; it went well. After a few minutes I made a back-up again and the MB restarted after about one minute.
De MB was 5 month ago for repair to Boris.
I'm getting a bit desperate from the MB pro :x
Posted: Mon Mar 11, 2019 10:11 pm
No idea what you are doing here. The provided backup script does backup on a USB stick not your Mac Book ;-)
BeBe wrote: Wed Mar 06, 2019 3:44 pm Size: 27,3 MB
The last backup:
You have mail.
logout
Saving session...
...completed.
[Proces voltooid]
Can you please give me a remote login. From the material you post I can get no insight.
Posted: Tue Mar 12, 2019 7:06 pm
by BeBe
A remote login has been sent.
BeBe
Posted: Sat Mar 16, 2019 8:29 pm
It turned out that doing the low level copy forces a reboot (caused by too low RAM) when database reaches a certain size. This is solved by pathing the backup script to do copying in small chunks. This issue did come a bit as a surprise as it is rather strange behaviour. However, this issue should be solved with latest update.
Posted: Sat Mar 16, 2019 10:10 pm
by BeBe
Thank you.
I did a reboot (twice), but the release did not update and remained: Meteobridge 3.9 (Mar 13 2019, build 12718), FW 1.4.
I made a back=up and the MB did a reboot again. Unfortunately it is not solved yet.
Posted: Sun Mar 17, 2019 1:37 pm
by BeBe
I did a restart and then I got March 17 release. The backup went well after that.
However, after a few minutes a reboot followed ... :(
BeBe
Posted: Sun Mar 17, 2019 1:46 pm
I was testing and issued a reboot. My test did run fine. I am off now.
Posted: Sun Mar 17, 2019 2:27 pm
by BeBe
OK. I was hoping for that. I assume it is now resolved.
BeBe
