A quick question: Our power cycled last night and I received the new 12617 build (FW 1.4). I noticed this morning that previously working templates no longer work. Nothing changed for me other than the update to FW 1.4. I can log into the station just fine via a browser; all services are back up and showing good connection(s).
Here is the template that worked with the previous firmware:
http://meteobridge:<password>@ip-of-met ... ?template=[th0temp-act=.1:---],[th0hum-act:---],[th0lowbat-act:---]
-- or --
http://ip-of-meteobridge/cgi-bin/template.cgi?template=[th0temp-act=.1:---],[th0hum-act:---],[th0lowbat-act:---]
Edit: The request eventually times out with: The CGI process did not produce any response
Current Specs
Platform: TL-MR3020 (no USB hub)
RAM: 29364 kB total, 3940 kB free (86% used)
SW Version: Meteobridge 3.8 (Jan 1 2019, build 12617), FW 1.4
Uptime: 0 hours, 22 minutes Buffer: 3 items (0%)
I am at a loss; everything was working great until the update. Any and all help would be appreciated!
Help - please: Templates stopped working after update to build 12617 **solved**
- Mike.Manzo
- Fresh Boarder
Re: Help - please: Templates stopped working after update to build 12617
This won't help you much, but BOTH of my MeteoBridges (TL-MR3020v1 & TL-MR3020v3) respond to your template immediately, without any errors
Have you tried rebooting your bridge and/or your router? That sometimes clears up transient errors for me...
- Mike.Manzo
- Fresh Boarder
Thanks ... that makes it worse.
I have rebooted the bridge multiple times; will try the router next. Templates are the only thing not working. Live data returns immediately as well - just as expected.
Curious, SANdood ... you have the 12167 build?
Thx.
Thx.
Indeed I do - I should have mentioned that.Curious, SANdood ... you have the 12167 build?
I've experienced similar timeout issues, and it almost always seems to get cleared up by rebooting the bridge and the router/nameserver/DHCP server (usually all on your router, but my environment is a bit more complex).
- Mike.Manzo
- Fresh Boarder
Re: Help - please: Templates stopped working after update to build 12617 ***SOLVED ***
*** Solved ***
Well - SANdood gave me an idea ... I had rebooted the bridge many times. I had not powered it down completely. So - I tried that and voila ... she started working as before.
Thanks SANdood ... Great suggestion.
-- M
-- M
