MB does not reconnect if 3G connection was lost
Bastian
Post by Bastian »
I use a Huawei E160 Modem with O2. After the start of the the mb the modem is connected to the mobile network and everyhing works fine (blue LED of the modem shines permanent). But when the mobile connection of the Huawei was lost (LED is blinking) there is no automatic reconnect until i reboot the mb manually. Is there any job or task which looks if the mobile connection is available?
Re: MB does not reconnect if 3G connection was lost
Automatic reconnect works fine with my setup. Are you on most recent Meteobridge SW?
Bastian
Post by Bastian »
Yes i tried it with the most recent version and also with the version 3.8. In both versions there was no reconnect until i restart the mb manually.
When I test the same modem on my TL MR3020 3G Router everything works fine. So the modem with the sim works well. Which modem and provider did you use?
