NanoSD Timeout & Disconnect
Snippet of the log when WeatherLink appeared to connect, was accepted, then was timed out & disconnected. This appeared to be between the console (Vue) and Nano as the WiFi connection was all good. At 16:57:14 all that was done was a [Save and Apply] on the System tab. Between 04:44:15 and 15:57:14 Nano was accessible via WiFi but not logging or updating any services etc. Anybody seen a similar occurrence?
logger (16.01.2019 04:33:26): 192.168.0.249's request on port 22222 accepted.
logger (16.01.2019 04:44:15): child process received timeout signal (14).
logger (16.01.2019 04:44:15): disconnect station 0 (Vantage): exit
system (16.01.2019 16:57:14): stop of logging process initiated.
system (16.01.2019 16:57:20): start of logging process initiated.
ConligWX
Re: NanoSD Timeout & Disconnect
Post by ConligWX »
Sorry cant help as I dont use weatherlink. I wonder if there a way of getting the nano to create debug logs for this type of behaviour and maybe show more information for you.
