LAN Addresses, 16 & 20 Bit.
WETBOTTOM
Post by WETBOTTOM »
I now have Spectrum Business Class Service which uses 20 bit LAN addresses like 172 .19 .0 .23.
I had to do this to get a static IP address, but now I fear, I may have created a monster!
Before I reset back to the default LAN address ( a 16 bit address like 192........), I would like to
know if my MeteoBridge will work with a 20 bit LAN address. Will it work with a 20 bit LAN address??
If not, if I get my own Wireless Router and use my own network (with 16 bit addresses and the Spectrum Modem), will I be OK with MeteoBridge??
WETBOTTOM
Private IPv4 addresses
RFC1918 name IP address range number of addresses
24-bit block 10.0.0.0 – 10.255.255.255 16777216
20-bit block 172.16.0.0 – 172.31.255.255 1048576
16-bit block 192.168.0.0 – 192.168.255.255 65536
Re: LAN Addresses, 16 & 20 Bit.
I don't see a problem, but never tried. I think there is no way around doing a test yourself?
You can reset to default LAN config as described in wiki's "getting started" section. So no risk ;-)
