Meteostick + Meteohub combining an anemometer transmitter + solar + UV
sander.pex
Post by sander.pex »
I have a Davis Pro with the following sensors connected to the Davis ISS:
- Rain
- Temp + Hum
- UV
- Solar
The following sensor is connected to a 6233 transmitter:
- An anemometer
I want to connect the UV + Solar sensor also in the same transmitter as the anemometer. I figured out that it is not possible with the standard Davis console because you cannot assign the UV + Solar sensors to a transmitter.
I have read the following interesting application with a MeteoStick:
MS+MB can also receive data from transmitter combinations that cannot be accessed by standard VP2 and Vue consoles. For example, an anemometer transmitter CAN be fitted with solar and UV sensors (as well as anemometer) and the data all received by the MB unit. (Indeed, an IM Sunshine Hours recorder could also be attached to the rain gauge input)
https://www.weatherstations.co.uk/meteo.htm
This example is with MeteoBridge. I want to do it with MeteoHub software running on a RPI.
Does anyone have expiriance with the MeteoStick for this application?
Re: Meteostick + Meteohub combining an anemometer transmitter + solar + UV
should work like with Meteobridge.
