bad data meteoclimatic format. **solved**
jmontamat
Post by jmontamat »
Meteobridge 3.9 (Jan 22 2019, build 12695), FW 1.4
bad format date
*UPD=2019-01-22 17:08
the corret is
*UPD=22/01/2019 18:12
geoair
Re: bad data meteoclimatic format
Post by geoair »
Hi @jmontamat
This situation is already discussed here:
viewtopic.php?f=56&t=13404
jmontamat
Post by jmontamat »
yes but no solution. :(
Did you do a reboot to grab latest hot-fix release two days ago?
jmontamat
Post by jmontamat »
Yes
Meteobridge 3.9 (Jan 25 2019, build 12696), FW 1.3
*VER=DATA2
*COD=ESCAT4300000043749A
*UPD=2019-01-25 10:42
It would have to be:
*UPD=25/01/2019 10:42
Please reboot. I made a hot-fix that should have this problem solved.
jmontamat
Post by jmontamat »
*UPD=25/01/2019 12:58
now if you thank you !!!!!
