Error: Finger print of application and system do not match
kds
Post by kds »
I just went through the setup of a new Meteobridge Nano SD, and I'm receiving the "Error: Finger print of application and system do not match" message on every screen of the web UI. What's causing this? I have accepted the license terms.
Re: Error: Finger print of application and system do not match
That happens when the firmware versions between the Nano and what's on the card are different, do a full reboot
kds
Post by kds »
Thanks Matt. I've been having some issues with it not coming back up after a full reboot but the error seems to have gone away.
With the SD it needs a reboot to pick up the version to support the card, then it needs another reboot to recognize the card, the firmware version showing at the end of the SW version (System tab) should now be FW 1.3, SW version will be relative to your Version control: settings
kds
Post by kds »
After rebooting several times, the message is back. I'm running Meteobridge 3.9 (Jan 26 2019, build 1918), FW 1.3.
