Hello -
A quick question: I have a number of System Variables that I am grabbing via templates. All of them work great with the exception of 1: [mbsystem-station:--]. When I use a simple query with this template, this particular template doesn't return anything - like nothing. Not even a "--" for a failed template query; it's blank.
Specs:
Platform: TL-MR3020 (no USB hub)
RAM: 29364 kB total, 3684 kB free (87% used)
SW Version: Meteobridge 3.9 (Feb 3 2019, build 12710), FW 1.4
Station: Meteostick: WS1000
Any help would be appreciated. If [mbsystem-station:--] isn't right, please let me know.
[mbsystem-station:--] Returns Nothing
- Mike.Manzo
- Fresh Boarder
- ConligWX
Re: [mbsystem-station:--] Returns Nothing
try [mbsystem-station]
Regards Simon
https://www.conligwx.org/pws
- Mike.Manzo
- Fresh Boarder
Same thing ... [mbsystem-station] does not return anything either.
Thanks for the suggestion.
Mike you may have found an oddity. I get the same results.
Tested some of the list if selectors (mac thru uptime) all work as documented, except "station" When I try something like [mbsystem-ERROR:--] the output is "--". Looking at the generated code output I see that [mbsystem-station:--] returns nothing (a null). I also checked [lgt0total-act:--] (Note I do not have a lightning strokes sensor so there should not be a stored variable) and that too returned "--".
I interpret all this to mean that "mbsystem-station" is valid and has "" (nothing) stored in it. Whereas ERROR or 'lgt0total-act' variables do not exist so "--" is returned/displayed.
Of course this is just me looking from the outside.
Lou
- Mike.Manzo
- Fresh Boarder
Thanks, Lou! I am glad I am not losing my mind.
I can also verify your results. [lgt0total-act:--] returns "--" for me too (I don't have a stroke sensor).
FWIW: I do have a station selected in the station tab under the "Weather Station" tab. I would have expected [mbsystem-station] to reflect that selection.
-- Mike
-- Mike
Yes I have the "RF Module: Vantage" selected on the <station> tab. If you too, that may be the issue. All the other options are a simple station definition, whereas the Vantage could have several option and therefor what to return is more complicated.
Lou
Currently, the replacement string is never applied, even when the template variable returns an empty string.
Next update will handle template variables that return a string in a way, that if they return an empty string and a replacement is defined, then the replacement string will be returned.
- Mike.Manzo
- Fresh Boarder
Thanks for the answer. I guess I ma still confused. I have a station selected in the "Weather Station" tab. I would imagine the replacement string would only be a factor if NO station was selected. Or am I just not using the parameter correctly?
-- Mike
-- Mike
