I bought a Nano SD back in January (with one of the recommended SD cards). It setup perfectly, ran as expected for most of the month. The built in web page templates were really cool.
However, now and then it would reset itself for no reason. While the main functions seemed to work, all the customizations in the template would reset back to their factory defaults.
Then, two weeks ago, it simply stopped working. It blinks red - 5 seconds on, one second off - endlessly. I've reseated it in the Vantage Pro, I've removed the SD card and tried running without it, I've put the SD card back in, always the same.
The instructions on how to reset to factory fresh config by holding the little blue button down and waiting five blinks does nothing; pressing the button has absolutely no effect on the 5-seconds-on / 1-second-off red blink pattern.
This thing is less than two months old. What do I do? Any help would be greatly appreciated.
FYI I used the TP-link meteobridge for many years prior to this upgrade, and have since given it away to another amateur radio hobbyist for them to play with, so I'm a long time supporter. Just bummed my new hardware seems to be dead.
Dead nano-sd?
Re: Dead nano-sd?
probably a predictable answer but contact the supplier and get it exchanged , get yourself another tplink to fall back on always keep one handy in the event of things like this happening... unless boris has the magic answer ...brian G7LIJ not qrv...Tugrik wrote: Mon Feb 11, 2019 7:21 am I bought a Nano SD back in January (with one of the recommended SD cards). It setup perfectly, ran as expected for most of the month. The built in web page templates were really cool.
Re: Dead nano-sd?
for the tplink fallback option, is there a way to re-use the same license that the Nano SD has on it (so you don't have to maintain dual licenses)?
Re: Dead nano-sd?
That would be a query for Boris? But I would imagine No, they are 2 separate devices license wise based on their individual MAC addresses with the tplink also having a different license structure
Re: Dead nano-sd?
License transfer between NANOs, PROs and regular Meteobridge is not supported. transfers within product family are fine.
Did you try placing batteries in the console (to rule out power brown outs)?
